Opti-Direct Ignition
Old Apr 28, 2004 | 06:50 PM
Johnnynsac's Avatar
How many of you have this and is it any good?. It seems better then buying the whole opit itself.
http://www.delteq.com/products.htm
Old Apr 28, 2004 | 07:03 PM
Ekof96Z28's Avatar
After looking at that site im sold. Anythings gotta be better than the opti....
Its definently on my list of things to do.
Old Apr 28, 2004 | 07:06 PM
davepl's Avatar
I might be wrong, but it looks like it still uses the opti for the high res rpm sensor and the low rest crank position sensor.
That's the part that was causing my high rpm miss, so it wouldn't have helped.
Old Apr 28, 2004 | 07:12 PM
bunker's Avatar
That part would never go in the opti had the opti not undergone high voltage which causes rust in the optispark by the ozone created through a spark jumping, this rusts the opti inside even when vented & sometimes causes the electrical part aswell as the cap & rotor to fail.
Without this High voltage spark your optispark is just another sensor rotating which mostly likely will never fail.
Old Apr 28, 2004 | 07:27 PM
davepl's Avatar
Well, on mine when the miss occurred the RPM tach signal would drop, which is completely unrelated to the distributor part. The tach signal is generated by the optical sensors, so in my case that's the part that was causing the problem.
So don't say never...
93 RedBird
Nov 15, 2015 08:24 AM
IndyZman
Oct 22, 2015 02:17 PM
PopoFormula
Oct 12, 2015 04:19 PM
tommalcolm
Sep 11, 2015 03:39 PM
Aaront810
Sep 11, 2015 11:24 AM
