Opti delete
Old Jul 27, 2010 | 04:46 PM
  #31
sbs's Avatar
sbs
That graph says "doesn't need an LS1 PCM" pretty loudly.
Old Jul 27, 2010 | 05:26 PM
  #32
brucer's Avatar
why not use the ltcc conversion? its alot cheaper..
Old Jul 27, 2010 | 05:37 PM
  #33
RamAir95TA's Avatar
LTCC still requires a functioning optical sensor (the opti still remains). The LSX conversion completely eliminates it.
Old Jul 27, 2010 | 06:03 PM
  #34
brucer's Avatar
does the efi 24x conversion come complete for $1600? or you have to piece it together, adding an ls computer you obtain yourself? what about a wiring harness?
Old Jul 27, 2010 | 07:00 PM
  #35
funina91ss's Avatar
Not sure where your going with that? Explain further if you don't mind.
You can go on thier website and get a quote for what you will need. Like if you have the coils and pcm you can buy the 24X wheel and opti cover, and harness. Or build your own harnes etc... They are realy good about answering emails and giving you all the info you will need.
Old Jul 27, 2010 | 07:45 PM
  #36
brucer's Avatar
i went to their site..
looks like it would be near $3000 for a complete ,ready to go, kit.. a little too pricey for me, i'm a tightwad
actually i'm just broke
its a good looking outfit though.
Old Jul 27, 2010 | 08:27 PM
  #37
S10Wildside's Avatar
$3000? The 24x conversion does not even exceed $2000 if using cable throttle and a GM timing cover. Not sure where the extra $1000 came in there.
Old Jul 27, 2010 | 08:32 PM
  #38
brucer's Avatar
$850 for harness and another $100 something for the ls1 computer.
then add in 3rd party tuning software on top of it all, making it worthwhile to do it...
Old Jul 27, 2010 | 10:52 PM
  #39
funina91ss's Avatar
Only part I got off them was whats in the pics. I made my own harness. Got my own coils and pcm. If you don't have spare harness laying around their little wiring kit is a pretty good deal.
Old Jul 27, 2010 | 10:57 PM
  #40
funina91ss's Avatar
Updated pic
Old Jul 28, 2010 | 08:50 AM
  #41
6772owner's Avatar
Ok Im sorry if I missed this in the thread, but did you just "re-pin" the original harness to the LS1 PCM connectors? I assume the only things you really had to change were the Opti wires and the CPS? I am curious because I have a 96' LT1 swapped into my C10 and it would be fairly easy for me to just change to LS1 connectors and swap to the 24X system. I suppose you also have the harness for the coil packs, but whatelse did you have to mod from the factory harness?? Sorry for all the questions, I am fairly new to all this....
Old Aug 2, 2010 | 08:11 AM
  #42
funina91ss's Avatar
We hard wired in the coils in. Had to run a few extra wires in the harness for cam and crank sensor but other than that it's just swapping out pins and putting them in the right place. Nothing major is you have the pin diagram laying right in front of you.
Old Aug 2, 2010 | 08:12 AM
  #43
funina91ss's Avatar
Went to Clay City yesterday. Got my Moser 12 bolt w/4.10's swaped out from the 91. All runs were on 17" Nitto 555R's and 93 octane.
Best pass of the day with 3000 DA was
1.633
7.36
94.29 mph
11.497
118.448
All other passes were within a tenth of that as long as I didn't spin.
Old Aug 2, 2010 | 08:59 AM
  #44
plattted's Avatar
opti delete
Does the $1600.00 price include the throttle body? Will it need a MAF sensor? Is that included?, and a new air lid with filter, is that included?
It does sound good but all these additional pieces---. the '93 does not have a crank shaft key on the ballancer hub, not sure about the crank gear though.
Ted
Old Aug 2, 2010 | 09:03 AM
  #45
funina91ss's Avatar
Ted
Ah man a 93 is the worst one to do the swap on. You have to swap all the wire ends for the new style pins.
