opti?
Old Jul 9, 2009 | 06:50 PM
  #16
Have you checked it for codes?
Old Jul 9, 2009 | 07:11 PM
  #17
sick9lt1's Avatar
yes i have
Old Jul 9, 2009 | 11:50 PM
  #18
93FIRETURD's Avatar
And? Any codes? sounds like you may still have the timing off by one tooth on the spline, in otherwords take that opti off and be 100% sure it is on correctly, also double check your plug wires I know you said you did but it can't hurt to check again. If you are 150% positive of both your opti installation and your plug wire routing begin looking towards other problems. You say it idles and runs horribly is that right on start up or after a few minutes of running? If it runs ok for a while look into your o2 sensors.
Old Jul 10, 2009 | 08:05 AM
  #19
sick9lt1's Avatar
no it is when i start it up. but i dont see how i can have it off any that spline 0nly goes in 2 diff spots the first tim i put it on car would not start at all. now it dose. if plug wires are not on good will it tend to backfire. i dont see how i can have the spline in the wrong way. and are you thinking it is in the cam sproket wrong or in the opti wrong.
Old Jul 10, 2009 | 05:27 PM
  #20
In the course of posting here over a 10 year period, I'd guess I have seen at least a dozen cases of people who were 100% certain they didn't screw up the splines.... only to eventually find out they did.
We still didn't get an answer on whether there were any codes, only that you checked for them.
I'll drop the subject since it appears you aren't really interested in what I have to say.
Old Jul 11, 2009 | 12:56 AM
  #21
sick9lt1's Avatar
lol dude calm down you are allways so crabby. you said did you scan foe codes i said yes sorry i did not put there were not any. i had the spline on the wrong way then took it off and put it in the ONLY OTHER WAY IT WILL GO. so i am lost i dont see how it can go any other way. i ahve tried to put it in and there were only 2 ways it will go one way the car wont start the other way it will but runs like crap with allot of backfires. what ealse can i do.
Old Jul 11, 2009 | 06:32 AM
  #22
Originally Posted by sick9lt1
lol dude calm down you are allways so crabby......
That's odd.... the thousands of other people I've helped over the year don't seem to think so. But you're entitled to your opinon.
Good luck.
Old Jul 13, 2009 | 07:02 AM
  #23
Future_Z_Owner's Avatar
You may have a bad opti. From the sounds of your first post you are trying to put on a new one. Where did you get it from? It could be DOA.
Formula Steve
Sep 19, 2023 08:31 AM
94Maroz28
Oct 27, 2015 04:38 PM
Ks0209
Oct 1, 2015 07:32 AM
colts0455
Sep 27, 2015 01:07 PM
jayblev95
Sep 26, 2015 09:44 PM
