ported intake manifold problem
Old Jul 11, 2009 | 09:28 AM
mikemassi's Avatar
i just got finished putting a ported intake manifold on and after everything was all done i started the car and it stalls right away. if i keep hitting the gas it will keep running but the second i let off the car stalls. anyone have any ideas?
Old Jul 11, 2009 | 10:30 AM
RUDEDOG's Avatar
Sounds like you have a massive vaccum leak somewhere. Did you forget to hook up the brake booster?
Old Jul 11, 2009 | 04:11 PM
Or you forgot to connect the harness to the IAC motor.
Old Jul 12, 2009 | 09:13 AM
95Blackhawk's Avatar
If that is all you did, it is something simple.
Old Jul 13, 2009 | 09:34 AM
PWR SHFT's Avatar
Was the intake mounting surfaces angle milled? If your heads were not surfaced and the intake was, then that could cause some serious sealing issues.
Old Jul 13, 2009 | 03:45 PM
JAKEJR's Avatar
First thing I'd do is re-check the connection to the IAC, TPS and coolant temp sensors. Then I'd begin checking for vacuum leaks; hoses and gaskets.
Jake
West Point ROCKS!
Noenav
Mar 1, 2019 07:38 AM
Noer
Feb 28, 2015 11:29 AM
CARiD
Jan 27, 2015 06:27 AM
Elcojoe
Nov 17, 2014 10:27 PM
Jul 4, 2005 05:00 PM
