opinions on this cam please
Old Jun 11, 2003 | 11:22 PM
CrippleFightin's Avatar
Comp Cams 230XL Camshaft 230/236 duration @ .050", .544"/.555" lift with 1.6 rockers. Think I could pass emissions with this and Hooker LTs or even MAC 1 3/4" midlengths?
My emissions are in Illinois so they have the sniffer and thats about it.
Old Jun 12, 2003 | 03:29 AM
Anybody? Please! I really need help deciding!!!
Old Jun 12, 2003 | 03:36 AM
sideways_Into_3rd's Avatar
with some extensive tuning .. and a bunch of cats maybe
im gonna try to pass my CC306 by running my 2 FLP cats and adding a stock cat at the end .. if that doesnt work .. i'll keep adding more cats till she passes
Old Jun 12, 2003 | 03:42 AM
bunker's Avatar
it would be very hard, probably not worth it either, big cam is a big cam. just put in a small cam everytime you go through or find a way to get around it
Old Jun 12, 2003 | 03:49 AM
damn, i guess i should just go with the cc305
Old Jun 12, 2003 | 06:03 AM
D James's Avatar
Well cats need to be heated up, so they must stay close to the headers or manifolds, this is why the government forbids moving them to a new location, adding a new one to the end of your exhaust would only waste your money, may not help you pass at all. There have been some that say a cc306 will pass with a tune just specified for passing, that must be programmed in right before your test, so there must be a way. I imagine it depends also on the state, since they're all different levels and such. As far as that 230/236 I don't think it will pass well either, I assume it has a 110-112 LSA which will make things worse. I did read a post of a 224/230 might be a better choice. I just put in a blower cam, and that thing blows out some serious fumes, I could'nt imagine a huge cam with lots of overlap
Old Jun 12, 2003 | 02:34 PM
HtownZ's Avatar
cc305 and cats
Old Jun 12, 2003 | 02:42 PM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
why not the 224/230?
btw- cats aren't filters
adding more isn't going to "clean" the exhuast
Old Jun 12, 2003 | 10:47 PM
I was debating between the cc305 and the 224/230. I want a 114 LSA so i am not sure how that works. I know the cc305 is 114 not sure about the 224/230.
Old Jun 12, 2003 | 10:52 PM
treyZ28's Avatar
you can get it ground to what ever lobe seperation you want
rideordie
Nov 5, 2019 04:52 PM
carl.froehlich
Mar 13, 2015 12:38 AM
IgorT.455/406
Mar 12, 2015 03:39 AM
