Opinions on Autolite 106's for heads & cam cars
Old 05-10-2005, 08:18 PM
ZDriver96's Avatar
I just put in autolite 106's gapped at .40. I have Heads/cam and 11.1 compression.
It was done in an effort to fix my 1/2+ throttle stumble/miss.. Its a hard miss when i go above 1/2 throttle in any gear. Its like the car just tapped its brakes when i start to get on it.
Anyways it didnt fix the problem.. I was running NGK TR6's but thought they could have been bad after 7 months of sitting around.
Think the autolites will be ok?
ZDriver96 is offline
Old 05-10-2005, 08:25 PM
OBE1 95Z28's Avatar
Re: Opinions on Autolite 106's for heads & cam cars
The TR6's are one range colder than stock, how did they look (white, black, tan)? The 106's are stock heat range.
OBE1 95Z28 is offline
Old 05-10-2005, 08:32 PM
ZDriver96's Avatar
NGK's were white... So they were still good so it seemed..
Im guessing my 1/2+ stumble is plugs or tune...
Should probably hook up my fuel guage and watch it while i accelerate too though..
Yeah i didnt know if having 450hp at the fly would be ok for stock heat range plugs...
I know for sure not to use nitrous with them... but not so sure NA since ive heard different opinions
Old 05-10-2005, 08:40 PM
OBE1 95Z28's Avatar
White plugs mean you're running lean, tan is the color for the right combo. The 106's are going to run too hot; especially with 11:1 compression. If you have 450 HP, good chance your fuel injectors aren't keeping up causing you to run lean. Have you upgraded injectors and gotten a dyno tune with a wideband O2 sensor?
Old 05-10-2005, 09:06 PM
ZDriver96's Avatar
30lb SVO injectors...
So maybe the stock fuel pump isnt pumping enough higher up??
Hmmm.... yeah... white too lean... hmmm
Damn it...
Had it on the Wide Band/ Dyno but it was spinning a bearing so we were getting all kinds of weird crap...
SO im getting a mail order tune from Madz28.com / Ion. Just thought i'd try the plugs.. I'll swap back in the NGK's then...
I ran a free scan on it but i dont know how to read it exactly or what to look for.
BLMS aroudn the time it does it are at 128-135 on both sides.. up to 146 at some points.
Map is varies from .97 to .24 ?? TPS says 65 to 0 through all rpms.
MAT volts say 2.31-2.35 in the upper rpms
Timing at 35-38 in the upper rpms
Right and left O2's read 1.021 and .839 when i got on it right before it stumbled.
By upper rpms i mean 3500.
Noenav
03-01-2019 07:38 AM
oldschool
02-09-2016 09:21 PM
USAirman93
11-24-2014 03:37 PM
Queens94z28
11-20-2014 06:03 PM
NED4SPD
09-16-2002 10:45 PM
Quick Reply: Opinions on Autolite 106's for heads & cam cars
