anyone ever have a valve seat fall out??
Old May 10, 2005 | 05:50 PM
wlz28's Avatar
when my motor blew it cracked 2 pistons and at the same time ( I don't know if one caused the other or what) a valve seat fell out on the exhaust side. why would a valve seat come loose??? Ive never herd of anything like that before. They were ported with 2.02 1.6 valves
Old May 10, 2005 | 06:00 PM
Spinner's Avatar
Re: anyone ever have a valve seat fall out??
I've had one come out myself. No idea why.
Old May 10, 2005 | 08:34 PM
wlz28's Avatar
did your heads have bigger valves??
Old May 10, 2005 | 08:42 PM
Mindgame's Avatar
Seen a few come out.
My guess is it has something to do with the heat in the head. Seen this most often in heads that have (improperly) been welded on and/or engines that have become too hot. Probably softens the head.
On something catastrophic, like a part letting go.... there's no telling. Could have hit the seat, knocking it out-of-round and there ya go.... the thing comes out.
-Mindgame
Old May 10, 2005 | 09:02 PM
MachinistOne's Avatar
The most common reasons for dropping a valve seat are in no perticular order.
-Machinist did not setup the press(interferance fit) correctly and they drop when the aluminum expands faster than the iron.
-Head is cracked at the valve seat area and so the aluminum has lost it's hold on the seat.
-Some factory installed powdered metal seats become brittle and shatter after 1000's of miles.
Old May 10, 2005 | 09:03 PM
nateh's Avatar
I lost a seat on one of my Brodix heads when they were in the car. I think Mindgame is correct. If aluminum heads lose their heat treatment from too much heat, they get soft and bad things happen. In my case, I believe it happened long before I got them, so I was doomed. You can get heads heat treated again. Luckily, mine dropped at idle so it just munched the chamber and the top of one piston. I replaced that piston, put the stock head castings back on (ported), and replaced the rings and bearings.
Old May 10, 2005 | 09:07 PM
As the L98/LT1 series heads cannot support a 2.02" valve without putting a bigger seat in, I would assume that the press is not correct, they may have put in too much press and deformed the exh seat area so that it dropped out. It would be smart to have the seats TIG'd out and have the press check to make sure it doesn't happen again.
dylan1303
May 22, 2015 12:24 PM
MyShibbyZ28
Feb 14, 2015 12:05 PM
Jazsun
Dec 29, 2014 12:14 PM
Timberwolf
Jul 30, 2002 08:31 PM
