Open/Closed Loop idle issues (Videos)
Old Apr 28, 2013 | 02:27 PM
moonscar's Avatar
So my car idles pretty hard before it enters closed loop. Sometimes it can drop as low as 300 rps. Low enough to stall, as the video shows
Here is a open loop video:
VID_20130426_185119_zpsa3d193a2.mp4 Video by anonymousperson4life | Photobucket
Here is a closed loop video:
VID_20130426_191504_zps30b92f0f.mp4 Video by anonymousperson4life | Photobucket
Would there be anything obvious to you that would cause this issues? Once warmed up and it switches into closed loop the car is a dream. It just sucks waiting for it to warm up to switch over. Makes 1/4 mile tracks runs hard to do if your car sits in the pit too long
Old Apr 28, 2013 | 02:38 PM
Re: Open/Closed Loop idle issues (Videos)
Couple things.... need more info - we can see it's a 4th Gen Camaro, apparently a Z28, but what year? I'm guessing it's an LT1, but I could be wrong. What modifications? Doesn't quite sound like a stock cam. If it's not stock, list the mods. "Signature" field is useful for that info.
And "Drivetrain" is for trans and rear axle topics, so let's move this to the correct engine tech forum, once you identify the engine.
Old Apr 28, 2013 | 07:28 PM
moonscar's Avatar
dang. i was hoping you would not need that info. here comes the challenging part
lt1 with lt4 heads and hotcam
powerdyne 6lb boost supercharger
also sorry about the wrong thread. thought i was in engines
Old Apr 28, 2013 | 10:51 PM
OK.... let's move this to LT1 Based Engine Tech".
When you bolted the LT4 heads on, what intake manifold did you use?
Old May 3, 2013 | 04:20 PM
moonscar's Avatar
It's the lt4 intake as well. I don't think the lt1 would have fit anyway
Magenta_Hearts
Mar 5, 2015 07:01 AM
ChrisFrez
Mar 1, 2015 01:33 PM
David Dorris
Jan 17, 2015 08:10 PM
tbyrne
Jul 2, 2002 05:37 PM
