OP Drive Shaft through top??
OK Like an idiot I sealed up my bottom end without installing the oil pump drive shaft. I tried dropping it in through the intake side of the engine in to the hole but it doesn't seem to squeeze through the lower hole to connect to the pump. Does this have to be installed from the oil pan side?
oh yeh, and the intermediate shaft usually has that redish/brown plastic piece that acts as a coupler between the pump shaft and the intermediate shaft. mine is cracked. i'm assuming this peice steadies the rotation to keep it centered?
squarehead
Nov 21, 2014 08:02 PM
