oops, now what?
Old May 24, 2013 | 02:14 PM
sabresfan's Avatar
oops, now what?
Somehow I managed to screw up putting my alternator back on.
Any suggestions?
I drove it like this for a bit today and the alternator still seems pretty sturdy. Should I replace the whole bracket?
Old May 24, 2013 | 02:17 PM
Re: oops, now what?
That or probably easier to get a piece welded to it and re-tap it for the bolt.
Old May 24, 2013 | 02:23 PM
Scrub88's Avatar
Re: oops, now what?
Either replace or weld on some new metal only temporary Jerry rig fix I see is to remove the rest of the broken area and put a nut on the bolt ..relying on the to black support brackets for some strength .
Old May 24, 2013 | 02:25 PM
Re: oops, now what?
Please don't test the language filter.
Old May 24, 2013 | 03:29 PM
sabresfan's Avatar
Re: oops, now what?
my bad. i added the ****
hopefully i can figure something out...
anyone know the part number for a whole new bracket or if they're even available?
Old May 24, 2013 | 03:54 PM
John95z28's Avatar
Re: oops, now what?
Get slightly longer bolt and nut with washer. Tighten that as a sandwich. Looks like there is enough meat left to grab tight. A temp fix that should work good and cheap.
EDIT: use the broken piece in place to keep it even.
Re: oops, now what?
10239875 does not appear to be available.
Old May 24, 2013 | 04:54 PM
sabresfan's Avatar
Re: oops, now what?
good call, I might try that. Although every time I go to home depot for bolts or screws for my car they never seem to have the right kind of thread
Old May 24, 2013 | 06:01 PM
John95z28's Avatar
Re: oops, now what?
No prob just get a slightly narrower bolt if you can't match one perfectly.
Timberwolf
Sep 2, 2003 02:34 PM
