Only getting 21MPG Highway, suggestions?
Old Jul 17, 2007 | 04:32 PM
  #16
The Captain's Avatar
Just had to refuel again today, Only got 217 miles out of the tank 60/40 highway/city driving, which equates to 14.6MPG
Old Jul 17, 2007 | 07:11 PM
  #17
TobyZ28's Avatar
Get a scanner on the car and watch for knock retard. Your cutout being open all the time may be causing the engine to retard timing reducing your milage drasticaly.
Old Jul 17, 2007 | 08:36 PM
  #18
elisowski's Avatar
Originally Posted by The Captain
No o2 sensors on the 93s, it is an A4 and shifts perfectly, car runs fine, it will get up and go with no hesitation or anything. As far as I know, it still has the factory plugs and wires. It is throwing a code 26, which is the EVAP system, but I wouldnt think that would hurt fuel economy too much The cheap cone air filter looks like it could use a cleaning, but its really not that bad.
If the EVAP system is broken, it could draw clean air into the manifold (vacuum leak). The MAP sensor will read a higher MAP value (lower vacuum)and ADD fuel because it "thinks" you have the throttle open more than you really do. Adding the fuel will cause you to run rich (burning more gas and eating into your mpg) and foul the plugs (poorer combustion).
I'd have the code checked and fix the problem. Then clen or replace the plugs. It could be the cause of your lower fuel mileage.
WPHIG2
Aug 27, 2015 06:37 AM
Louey
Pacific
Aug 25, 2015 01:53 AM
Louey
Pacific
Aug 7, 2015 01:47 AM
CARiD
Exhaust System
Aug 3, 2015 05:10 AM
Louey
Pacific
Jul 27, 2015 09:58 PM
