View Poll Results: Which one is the right choice?
Procharger
11
37.93%
Stroker 383
17
58.62%
Stroker 355
3.45%
Voters: 29. You may not vote on this poll
Which one Stroker or Procharger
Old Sep 22, 2006 | 02:24 PM
BadCamaro's Avatar
Exclamation Which one Stroker or Procharger
Which one will get more hp, economical, less problems, daily driver? It will be for street racing
Old Sep 22, 2006 | 02:42 PM
wrd1972's Avatar
Re: Which one Stroker or Procharger
There is no 355 stroker. A 355 is a 350 bored .030".
That would be my response to your poll based on your needs.
Old Sep 22, 2006 | 02:54 PM
2000GTP's Avatar
The Procharger will be the easiest to install and most likely yield more power. Depending how much boost you want to run will determine how long your stock shortblock will last though.
Old Sep 22, 2006 | 03:25 PM
ulakovic22's Avatar
Procharger by far has the most potential, but you will need to step up on your shortblock to handle the boost once your stock one takes a crap. If you leave it around 4-6 psi you'll be fine for a while but once you start swapping pullies you're on borrowed time.
Old Sep 22, 2006 | 03:48 PM
Built LT1's Avatar
I am on my second 383. They are costly and time consuming. I voted Procharger because it should be more power and less problems.
What's a stroker 355?
Old Sep 22, 2006 | 04:07 PM
Severous01's Avatar
why not go with some new 030 pistons...and procharge . that way you get the best bang for the bucks.
if you charge a stock high mileage motor you're likely to blow something, but...if it were one or the other i'd do the procharger over anything else just because it's easier and less time consuming. if i had the 4 grand i'd go that route.
Old Sep 22, 2006 | 04:37 PM
nick3's Avatar
why not a 383 and a supercharger. or even a turbo and 383. im doing a 383 now and plan on adding a turbo or super charger later. if you want to do a 383 the right way you still want to forge everything anyway, so it would be set up for a super/turbo charger. just keep the cr lower. thats why i went with the 383 first, then everything is set up for my charger later, and i dont have to worry about my high mileage engine.
Old Sep 22, 2006 | 05:34 PM
lt11997's Avatar
I would do the 355 and procharger.
Old Sep 22, 2006 | 05:47 PM
MTL_Z28's Avatar
I suggest a 0.030 overbore, forged pistons (bump the CR), refresh the bottom end with clevite bearings, a off-the shelf cam kit with a good nitrous cam, LT's, and a hidden wet 175 shot....
That shouldn't break the bank too much, will be ok for street driving and will win you quite a few street races
Old Sep 23, 2006 | 05:56 PM
blown383's Avatar
383 and blower. But my opinion might be a little biased.
-B
Old Sep 23, 2006 | 08:01 PM
buzz12586's Avatar
Go with the 383 and some juice. You can't hear cubes and juice. You can hear a blower.
Old Sep 24, 2006 | 04:06 PM
Craddock's Avatar
I thought that technically the lt1 is a 355 anyway.
Old Sep 24, 2006 | 07:09 PM
ryan woods's Avatar
IT is a lt1 bored .030 over
AviatorDave
Dec 19, 2016 06:35 PM
RUENUF
Mar 13, 2016 03:37 PM
95blkss
Sep 22, 2015 03:18 PM
95craz28
11
Sep 12, 2015 07:47 AM
95blkss
Jul 13, 2015 01:28 PM
