MOREL LIFTERS ... high rpm only?! ---
Old Sep 24, 2006 | 05:39 PM
AlwaysCode390's Avatar
Question MOREL LIFTERS ... high rpm only?! ---
I have been reading that the COMP R's are really only designed for TRACK USE ONLY , not for a Daily Driver and that is where most of the problems are coming from. I am wondering....since the Comp R's are a HIGH RPM LIFTER like the MORELS are ..... are the MORELS not good for a daily driver (noisy,reliability at low rpms, ect)?!
I am going to use my LE2 setup for daily driving ... so should I go with the comp 850's and call it a day? The stockers have too many miles....I dont want to risk reusing them. They are good enough for my 1.6 rr's, beehives, trickflow pushrods, and a cam in the mid to high .500 lift?! Thanks ---
Old Sep 24, 2006 | 06:33 PM
2QUIK6's Avatar
Re: MOREL LIFTERS ... high rpm only?! ---
I'm using OEM GM's, put them in new with the cam. I've got .597/.585 lift.
No issues at all. The Comp R's are the ones people have been having problems with, there's a "Sticky" on them at the top of the forum.
Old Sep 24, 2006 | 06:54 PM
SStrokerAce's Avatar
Depends on your spring pressure, if you are not going crazy with that and rocker arm ratio and didn't spin a bearing in the motor the stockers will work fine.
Bret
Old Sep 24, 2006 | 07:05 PM
Arent all the spring pressures on the le2 setups the same , or does he use different pressures for different le2 cams?! They are the beehives Lloyd put in , and I am using 1.6rr's. I guess the 850's are where its at since the stockers should be fine ---
Old Sep 24, 2006 | 07:14 PM
Yeah if you need new ones then the 850's but if you have stockers stick with those. We designed the LE2 setup to work fine with those lifters.
Bret
dfarr67
Apr 10, 2015 07:44 PM
1996LT1Z28
Mar 8, 2015 08:16 PM
siguy
Nov 27, 2014 10:07 AM
Redbird
Sep 14, 2002 09:18 AM
Redbird
Jul 20, 2002 06:08 AM
