One pushrod flows a lot more oil than the others. Problem?
Old Jun 10, 2007 | 09:51 AM
JP95ZM6's Avatar
I primed my motor last nite, and the #7 intake rocker fills with oil & overflows within in a couple of seconds, but all the others just have a trickle. Rotating the crank didn't change anything. What would cause this, and do I need to take any action? New build, but I reused the original lifters.
Thanks.
Old Jun 10, 2007 | 10:33 AM
buzz12586's Avatar
One of mine seems to do that as well. It flows a lot more oil than the rest of them. Not sure if it is a problem though.
Old Jun 10, 2007 | 10:54 AM
wrd1972's Avatar
I am sure you are fine, the drill does not recreate the same pressure that running motor will create. The lifters tend to be a little inconsistant at lower NON operating pressures.
Old Jun 10, 2007 | 10:57 AM
JP95ZM6's Avatar
Thanks for the fast input. Nice observation on the lifter inconsistancy at low pressure - that makes sense.
On with the intake install. Great fun on a sunny Sunday afternoon!
Old Jun 10, 2007 | 08:51 PM
buzz12586's Avatar
What if you motor does it at idle?
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Dec 1, 2016 05:37 PM
Roadie
Feb 16, 2015 10:34 AM
97 RedSS
Jun 10, 2003 07:58 PM
