once temp gauge hits 210, engine starts cutting out
Old Jun 5, 2008 | 11:11 PM
94Phoenix's Avatar
i made a thread awhile back about my car cutting out but i found out some more stuff that may help me. first off, my car is a 94 formula lt1, auto trans, slp cai and no mufflers. the car runs PERFECT until it hits 210, it bogs and cuts out and just will not get going, if i take off from a stop and get into it, the car takes off like a bat outta hell, but if im cruisin and its already shifted into 2nd, 3rd, etc. i hit it and it just bogs, WTF! any ideas?
Old Jun 6, 2008 | 03:57 PM
94Phoenix's Avatar
bumpety bump bump
Old Jun 6, 2008 | 04:18 PM
BUBBA's Avatar
I don't know. Is your coil ok? I'm sure someone else will chime in.
Old Jun 6, 2008 | 08:22 PM
Oxygen454's Avatar
I had this problem. I changed my plug wires and thew in some fuel injector cleaner and it was gone.
Old Jun 7, 2008 | 12:16 AM
94Phoenix's Avatar
also i did the throttle body bypass the other day hoping to help it stay a little cooler, and i read there should be quite a bit of coolant coming out of the hoses, and there was any that i saw come out. u think the coolant maybe isnt running right?
Old Jun 7, 2008 | 01:02 AM
94Phoenix's Avatar
i wasnt sure of the exact way to bleed the lines, so i unscrewed, screwed them back in, let the car run for a little bit and then did it again. but the first time i opened up the screws i heard a bubbly type noise, and the exhaust was smokin more than usual and smelt like old gas
Old Jun 7, 2008 | 02:27 AM
Oxygen454's Avatar
This might be way out in left feild but do you have coolant in your oil or oil in your coolant? There is a good bleeding process on shoeboxes website. Im just guessing but the bubbly noise could have been air trapped in the lines?
Scottylt1
Jan 8, 2015 02:48 PM
cmdeshon
Dec 27, 2014 10:06 AM
brentbrowning01
Dec 16, 2014 06:35 AM
ro2207
Dec 4, 2014 06:18 PM
Jul 4, 2005 05:00 PM
