95 z-28 camaro
Old May 26, 2008 | 12:42 PM
95z-28camarolt1's Avatar
95 z-28 camaro
The car was idiling fine at 1000rpms then it idled down to like 200 and stumbles. I can start it but all it does is stumble and die. It is getting fuel and spark anyone have any ideas.
Old May 26, 2008 | 12:57 PM
OBE1 95Z28's Avatar
How do you know it's getting the proper amount of fuel? Put a fuel pressure gauge on it to properly prove fuel to the fuel rail. Failing fuel pump, bad fuel pressure regulator or a clogged fuel filter could be your issue.
Old Jun 1, 2008 | 08:44 AM
I put fuel pressure gauge on it i have plenty of pressure and it is sparking on every cylinder. So now i am wondering if it is timing related
Old Jun 1, 2008 | 12:30 PM
OBE1 95Z28's Avatar
Make sure your intake elbow tubing is on correctly and not cut or folded over on the bottom lip; if there's air bypass the MAF sensor it will cause your symptoms.
Old Jun 2, 2008 | 06:37 PM
All of the intake tubing is on good, but it wont turn over enough for that to matter thanks anyway.
Old Jun 7, 2008 | 08:36 AM
fuel pressure bleeding out
I found out my fuel pressure tester was broke. I borrowed one and checked the fuel pressure when the fuel pump turns on it goes to 50psi then when it goes off it goes back down to zero. When you turn the car over it just goes back and fourth from 50 to zero. Any ideas?
F'n1996Z28SS
Aug 23, 2023 11:19 PM
spearous
Jan 12, 2015 11:03 AM
Eddie Z-28
Sep 4, 2002 11:58 PM
CamaroZBoy
Sep 1, 2002 09:48 AM
