OMG, open long tubes!
Old Feb 16, 2004 | 01:57 PM
  #31
TransAm219's Avatar
How do you take the power steering pump off anyways ??? when i did my install i couldnt figure out how to get it off !
the reason your emissions stuff wont fit is b/c GM went to a different size on the later model f-bod however the headers were made using the size that was on the earlier models
call jet-hot , they will know what you are talking about and will send you the adapters you need
Old Feb 16, 2004 | 07:25 PM
  #32
soontobeGN's Avatar
the power steering pump came off with two bolts. One is behind the pulley and can only be reached by aligning the pulley so that one of the holes lines up with the bolt. The other is on top but i think we had to go thru a hole for that one too. we skipped doing this at first and had to do it later anyway because we couldnt get the first bolt on the passenger side to thread.
Paul
drptop70ss
May 4, 2015 08:22 PM
LT14LIFE
Feb 9, 2015 09:35 PM
Cam's maro
Jan 30, 2015 09:21 PM
SpeedJunkee
Dec 9, 2014 10:17 PM
