OMG new 383 LT1 Not firing..
Old Feb 14, 2010 | 05:57 PM
qnitro's Avatar
OK guys I dropped in my new 383 into my 97 SS hard top, I had Daves in Newark build it for me (great looking motor).. It has a LE2 cam and heads, CSR EWP, Comp roller rockers, Griffen radiator,LT's, Billet Ram FW and clutch, big mouth LE intake, 58MM TB, and here is the kicker.. I bought a Billet MSD opti and coil/wires. I put everything in from the bottom of the car, so I assymled(assembled, I fixed this for injuneer the motor on the cradle and put up through the bottom.. Car looks great, everything is clean and done.. I thought... NO SPARK.. car cranks, no fire...I have replaced the coil and ICM with known good one.. no workie.. I pulled brand new MSD Billet opti off to make sure its aligned properly, no workie.. I swapped out Car computer with another 1997 LT1/ 6 speed.. No Workie.... what am I missing?? What could I have missed??? All you can hear is the starter cranking and the motor moving.. no fire.. expect EVERY once and a blue moon.. a small back fire.. ??? I am stumped..HELP
assymbled
Old Feb 14, 2010 | 06:23 PM
mdenz3's Avatar
Do you have a noid light to see if the injectors are pulsing?
If the injectors aren't pulsing and no spark, the the PCM isn't getting the Opti signal.
Old Feb 14, 2010 | 06:31 PM
qnitro's Avatar
I can smell fuel, when I pulled the plug.. I have good fuel presure. whats a noid light??
Old Feb 14, 2010 | 08:21 PM
meangreenchevy's Avatar
are you sure the cam dowel is the proper legnth? the 97 lt1 uses the longer dowel maybe its not in the opti all the way? just my .2 cents. is this shop in newark NJ? if so can you pm me there number and roughly how much you spent on machining thanks
Old Feb 14, 2010 | 08:28 PM
also a noid light is basically just a tester to see if the injecters are squirting fuel. if you dont have one just take the 4 bolts that hold the fuel rails to the intake manifold manifold out and pull the fuel rails off the intake.leave the whole assembly together and dont remove the fuels lines. put a piece of cardboard under the injectors and have someone crank it fuel should squirt on the cardboard. this is a lil messy but it will get the job done to see if the injecters are firing also be careful not to break the vaccum line that goes to the fuel pressure regulator. is the computer tuned for this set up you have?
Old Feb 14, 2010 | 08:32 PM
neil350's Avatar
Noid light is a tool that checks to see if you have voltage at the injector.
edit: Got beat to the punch.
Old Feb 14, 2010 | 09:06 PM
Have you scanned the PCM for codes?
"assymled" it????
Old Feb 15, 2010 | 03:39 AM
qnitro's Avatar
"assymled" it????
LOL... No spell check in a hurry/panic..
Old Feb 15, 2010 | 09:23 AM
ok.... DID YOU SCAN IT FOR CODES?
Old Feb 15, 2010 | 02:29 PM
qnitro's Avatar
Im going to pick up a hand held scanner today
Old Feb 15, 2010 | 04:50 PM
gillta95's Avatar
did you ground your wire to see if you have spark?
Old Feb 15, 2010 | 05:30 PM
grumpygreaseape's Avatar
plug your old opti into the 4 wire opti harness, rig up a spark tester at the coil turn on the ignition and spin the old opti by hand-do you see a spark at the tester? (this ASSumes the "old opti" was still functional.) yes and for sure-scan for codes.
Old Feb 15, 2010 | 08:57 PM
red 95 z28 lt1's Avatar
check your fuses as well
Old Feb 17, 2010 | 03:58 PM
94arcticwhiteM6's Avatar
noid lights are cheap at autozone. just go invest in one.
Old Feb 17, 2010 | 08:51 PM
dookie454's Avatar
You might want to pull the Injector fuses first... but by the sounds of it you have the Opti in wrong, I did this twice on my 1995/1996! Everybody say's it's impossible but it's not at all. There's something strange with the angle of the dowl and the opti when your trying to install it that makes it shift about 15 degrees, just enough to miss the intended hole.
I finally used a magic marker and put a dot on the opti seal surface inline where the dowel goes into, and put the cam dowel straight up, VROOM! Fired right up!
cristian1311
Nov 23, 2014 02:22 PM
Queens94z28
Nov 20, 2014 06:03 PM
Doug Harden
29
Jul 30, 2003 07:05 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
