OMG I got the optispark wet..Need help fast
Old Dec 11, 2005 | 03:52 PM
wrd1972's Avatar
I gave the engine a sponge bath and did my best to avoid getting the opti wet. I started it up and it stumbling and coughing all over itself and wont drive worth a crap.
I assume its the opti maybe its somthing else.
Right now I am letting the engine just run in the garage hopefully to dry it out.
The opti definitely has suction and fresh air.
Does anyone have any advice for this situation.
Old Dec 11, 2005 | 03:56 PM
moparman's Avatar
Re: OMG I got the optispark wet..Need help fast
Let it dry for a day or two. It might be alright after drying.
Old Dec 11, 2005 | 04:44 PM
wrd1972's Avatar
Okay it seems to be running fine now. I wonder if the plug wires or somthing else was the problem. The engine sounded horrible, it was really missing badly. I think I may have dodged a bullet.
Old Dec 11, 2005 | 04:58 PM
96capricemgr's Avatar
Any distributor will run badly if it gets wet internally and anything with a sparkplug wire will run bad if water gets to the terminals on either end.
Old Dec 11, 2005 | 05:44 PM
MyShibbyZ28's Avatar
Atleast it was a sponge bath, and not a hosing down (like I did). I ran it for about 45 minutes and let it dry out. It's been fine ever since. 182,000 miles on the stock opti too!
Old Dec 11, 2005 | 05:53 PM
Mean Green's Avatar
sometimes just enough moisture gets in to make it misfire, but not enough to destroy the opti. in those cases it's usually best to store it in a dry area and let it dry out for a while.
Old Dec 11, 2005 | 05:55 PM
kick Z tail out's Avatar
My water pump started puking all over my opti one day... I had to drive it home 15 miles, then the next morning fill the car with coolant, and drive it 35 miles to my friends' house so we could put in a new water pump. Never had an issue.
I guess the vented optis really are pretty tough (well, compared to the non vented). I bet you'll be fine from here on out.
Old Dec 11, 2005 | 05:59 PM
wrd1972's Avatar
Thanks all, my finger are crossed.
It seems like I did this once a long time ago.
Old Dec 12, 2005 | 10:19 PM
Ellis's Avatar
NEVER EVER run a car in a garage, even with the door open. That's how you make dead people.
Jeff1904
Jun 5, 2016 05:00 PM
PopoFormula
Oct 12, 2015 04:19 PM
football4life
Oct 4, 2015 07:48 AM
Z Power
Sep 19, 2015 11:19 PM
damnyankee36
Sep 9, 2015 07:06 PM
