Old CC306 runs 11.42@118.9mph!
Old Nov 21, 2004 | 09:18 AM
  #16
NightTrain66's Avatar
Re: Old CC306 runs 11.42@118.9mph!
too bad the LE 2 cam never got tuned out. The car was a rocket with that little 226/234 cam and ported heads with STOCK VALVES. 11.60's at 117 MPH was pretty fast for that set up.
I don't care how you look at it, 118 MPH is VERY impressive for a N/A LT1.
Lloyd Elliott
NightTrain66@msn.com
Old Nov 21, 2004 | 10:16 AM
  #17
90 Z28SS's Avatar
What RPM are you shifting at and what are you going thru the lights at RPM wise ? Man , with those gears you still have alot left in that combo . I had 3.73's and a 3200 stall and this cam still wanted a 4.10 gear . With this combo ( stock shortblock , Stg 3 MTI LT4's 2.05/1.60 , cc306 ) with my auto I went 117 . My buddy on the other hand with a 6 speed , 4.30 gear and heads not as good as mine went 121 N/A . We were shifting at 7K rpm .
Great times man , it should only get better for ya
Old Nov 21, 2004 | 11:15 AM
  #18
slimdawson's Avatar
I don't know if I have seen another auto pick up 24 mph from the 1/8 to 1/4. You're rolling
Old Nov 21, 2004 | 03:52 PM
  #19
gmr speed's Avatar
Are you using a slick or dragradial, Also is the bottom end stock. Those are amazing numbers. great job...
Old Nov 22, 2004 | 06:26 PM
  #20
T/A lt1's Avatar
The car runs on 26x10" ET drags right now but a new set of ET street radials will be going on shortly for some more N/A MPH! I shift about 6800rpms. The bottomend has a stock crank and rods. The car will run 120mph on motor when some better weather gets here and I get to tune on it a little. This was first time out! Thanks for the compliments guys. Later Clint
Old Nov 22, 2004 | 07:15 PM
  #21
tonylittell's Avatar
just wanted to let you know i got the intake and throttlebody today....
thanks alot...
tony
Old Nov 23, 2004 | 04:25 PM
  #22
T/A lt1's Avatar
Cool Later clint.
Iamherefornow
Jan 26, 2015 04:57 PM
Amshnock
14
Jan 18, 2015 11:47 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
dirtybird81
10
Jan 6, 2015 09:31 PM
