Is it okay to use stock pushrods for 2-3 days with guideplates???
Old Nov 18, 2003 | 04:24 PM
96 WS6's Avatar
I want to get my car running and I just found that I had a bent pushrod. I need to get it running so I can adjust the rockers and break the car in. I won't be doing any high performance driving, I just want it to be running until I get new pushrods from cmotorsports.
Old Nov 18, 2003 | 04:47 PM
Dave C. '97 Z28's Avatar
You can go down to Chevrolet and buy 1 hardened pushrod for about $8.00 I believe. As long as your pushrods are stock length, you should be okay with that.
You should double check if this is the one that's hardened, but I think the PN is 14044874.
I wouldn't run a non-hardened pushrod with guideplates. It may not wear all the way, but it'll certainly shave some metal into your engine over time.
-Dave C. '97 Z28
Old Nov 18, 2003 | 04:51 PM
BUBBA's Avatar
Sounds like you answered your own question.
"Bent push rod"
It's probably bent because its not hardened.
I would wait for the new PRs. No one can tell you what will happen. JMHO
Old Nov 18, 2003 | 05:04 PM
96 WS6's Avatar
It bent because the rocker was too tight. Please just answer that question I'm trying to get my car running.
Old Nov 18, 2003 | 05:19 PM
BUBBA's Avatar
Ok, my answer is, I wouldn't. Others may say it "should" be ok, but I doubt that anyone is going to say it "will" be OK.
I am, however, a bit conservative nowadays, having blown, what I thought was) a perfectly sound engine.
I wouldn't take MY advice if I were you.
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Dec 1, 2016 05:37 PM
Noer
Feb 28, 2015 11:29 AM
Catmaigne
Dec 25, 2014 12:16 PM
