OK to switch from synth trans fluid to organic?
OK, I just pulled my T56 and swapped clutches, and its back in. I filled up with Mobil 1 synthetic ATF and haven't driven the car yet. It has idled, and I've run through the gears a few times, but I'm having a problem and need to take down the trans again. Also, I have heard bad things about using synthetic in the T56. Can I just drain the synth. and fill up with organic? Especially since I have run much at all with the synth. Or is it like motor oil, and there's no turning back?
