ok now im upset!!!
Old May 18, 2010 | 03:00 PM
z28beast's Avatar
ok now im upset!!!
so i ordered replacement studs for my lt1 heads and they dont fit...there the arp 134-7104 replacement 3/8 studs....so i go to install them and i find out that there about 2.5 threads too long...so i call arp and they reccomend using hardened washers to fill up the space...wtf arp! apparently they dont make them any shorter than that....idk what to do now...anyone else heard of this problem?
Old May 18, 2010 | 03:03 PM
96capricemgr's Avatar
Sounds as if you are looking for non-guideplate studs.
The ARP studs are longer to make room for guideplates.
Old May 18, 2010 | 03:11 PM
RamAir95TA's Avatar
You used the wrong rocker studs, it's that simple.
Old May 18, 2010 | 03:30 PM
z28beast's Avatar
well i called summit and arp and both dont make anything with a shorter stud that threads into the block.....anybody have any part number?
Old May 18, 2010 | 03:52 PM
HRE's Avatar
HRE
Grind a few threads off. Big deal nothing about custom performance is straight forward. Maybe the factory didn't drill the heads deeper then there supose to be. Make it fit.
Old May 18, 2010 | 04:04 PM
bw_hunter's Avatar
I'd use washers before grinding a haredened stud...but that's me.
If you look in ARP's catalog, you'll see they list 2 3/8 studs, -7104 has a .710" thread length and -7101 has a .700". The other difference is the upper threaded portion...-7104 is intended to be used with roller rockers and the threaded portion above the head is longer.
Use ARP washer 200-8509. It's a 7/16" ID with a chamfered hole. The OD is 13/16" or you could alkways buy guide plates...
Old May 18, 2010 | 04:16 PM
94CamaroZ28/SSClone's Avatar
You changed the word "Pissed" with "upset" What happen to my reply?
Old May 18, 2010 | 04:33 PM
RamAir95TA's Avatar
134-7101.
Old May 18, 2010 | 05:38 PM
blackFbird_98's Avatar
I would just use guide plates and be done.. nothing wrong with going the extra mile in this case..
Old May 18, 2010 | 07:53 PM
If he is using SA rockers, he sure does not want to put guideplates on it.
Old May 18, 2010 | 09:40 PM
z28beast's Avatar
i didnt change it a mod prolly did....i called arp and got this all sorted out i think!!
Old May 18, 2010 | 10:02 PM
z28beast's Avatar
134-7101.
i took your advice and i exchanged the ones i had for these....will they work with my roller rockers?
Old May 18, 2010 | 10:12 PM
You quoted and questioned a post that was eventually deleted, because it was not appropriate. Your post was deleted as well. Is was not on topic.
Old May 19, 2010 | 05:05 PM
z28beast's Avatar
ok so well i got the new studs today and they still are hitting the little tang on the bottom of the hole....i tightened one down all the way and i got it to touch the surface of the head with little force so im just gonna say **** it and tighten them all down.....what is the purpose of that little tang? also what do i use when i torque the studs to the heads? do i just use thread locker or what?
Old May 19, 2010 | 05:51 PM
Yeah that's why I quoted the person that left such a bad reply. I remember I asked why he felt that way.
