ok now im upset!!!
ok now im upset!!!
so i ordered replacement studs for my lt1 heads and they dont fit...there the arp 134-7104 replacement 3/8 studs....so i go to install them and i find out that there about 2.5 threads too long...so i call arp and they reccomend using hardened washers to fill up the space...wtf arp! apparently they dont make them any shorter than that....idk what to do now...anyone else heard of this problem?
I'd use washers before grinding a haredened stud...but that's me.
If you look in ARP's catalog, you'll see they list 2 3/8 studs, -7104 has a .710" thread length and -7101 has a .700". The other difference is the upper threaded portion...-7104 is intended to be used with roller rockers and the threaded portion above the head is longer.
Use ARP washer 200-8509. It's a 7/16" ID with a chamfered hole. The OD is 13/16" or you could alkways buy guide plates...
ok so well i got the new studs today and they still are hitting the little tang on the bottom of the hole....i tightened one down all the way and i got it to touch the surface of the head with little force so im just gonna say **** it and tighten them all down.....what is the purpose of that little tang? also what do i use when i torque the studs to the heads? do i just use thread locker or what?
