Ok, I have a fresh TH400 trans sitting in my garage. now what do I need? 93z
Alright there wasn't too much comprehensive info when I tried the search on this topic. But what would be ALL of the parts needed to swap the Turbo 400 into my 93 Z28 to replace the 700r4?
I imagine it would be cheaper than spending $1200+ for a rebuild, since I already have a TH400.
So please list parts I would need, and price estimates. Also what is the overdrive unit that some people get?
You will need: aftermarket torque arm that does not mount to the tranny (Spohn or BMR Xtreme) You will also need the tailshaft housing,exciter ring for the VSS and the VSS sensor from a 454SS pickup for the speedo to work. You will have to slot a 6 speed crossmember and use it as well as getting a driveshaft made. Check out http://para.noid.org/~lj/TH400/TH400.htm for some good pictures.
Originally posted by Clubbin54
Ok, what shifters would work? Would any fit in the A4 console without too much cutting?
What about an overdrive unit?
I have a Mark Williams 3" chrome moly DS for sale, with TH400 input yoke, solid 1350 u-joints, for the TH400 without the GV. $425 + shipping. Need to check length, because my TH400 seems to be about 1" or so longer than normal. My 6-speed cross-memeber required an extension, not just slots.
I've got a Gear Vendor for the Super T-10. They say it isn't necessary to use the clutch when activating the GV but I'd recommend it. It slams hard. Not sure how "gentle" it is on an automatic. Enjoy!
james007moore
Jan 1, 2016 01:14 PM
