OK - how big is my cam? video clip
Old Aug 19, 2007 | 09:14 PM
chief455's Avatar
Due to lack of interest I will cancel the question. Thank you.
Old Aug 19, 2007 | 09:35 PM
NotACop97z28's Avatar
Im no cam wizard so I cant guess, but are you sure your ok letting it idle in your garage for 2 minutes...I thinki would have chocked to death on the exhaust. Sounds good though
Old Aug 19, 2007 | 09:48 PM
speed_demon24's Avatar
There's no way to tell what cam you have in there by listening to an idle clip. Get it on a dyno to find the right shiftpoints then get some track times.
Old Aug 19, 2007 | 10:16 PM
Z-RATED94's Avatar
Sounds a little mild, but does it have cats on it? If it's a 383 and shifts at 6500, I would "guess" it's a little bigger than a Hotcam. One quesstion though, if it shifts at 6500, how do you know it revs to 7k?
Old Aug 19, 2007 | 10:54 PM
'94 Bad A Z28's Avatar
Was gonna say the same thing, doesn't sound too big at all. If I had too guess I would say something in the 22x/22x range for duration on something like a 113 LSA. But there is really no way to tell for sure by listening to it.
Old Aug 19, 2007 | 10:56 PM
People can guess all they want. That is never going to tell you what it really is.
Old Aug 20, 2007 | 10:28 AM
SS MPSTR's Avatar
You can 'hear' the difference between 0.520" lift and 0.550" lift?
Old Aug 20, 2007 | 10:36 AM
RallyRed701/2's Avatar
in your sig it says that you have an lt1 intake with lt4 heads...? i didnt think that was possible...
Old Aug 20, 2007 | 12:50 PM
95_MuLLeT_LT1's Avatar
Originally Posted by chief455
No doubt that's true.
However - after 20 years of building Pontiac V8 engines I can come very close to the true cam specs just listening to a motor.
But, but, its not a Pontiac motor.
Old Aug 20, 2007 | 01:26 PM
Overlap is what causes the lope, and there is more than 1 way to get the same overlap.
A 240/240 cam on a 112 lsa has teh same over lap as a 228/228 cam on a 107 LSA but they would both idle identicle with the same lope, but one is 12 degrees bigger. Like everyone is saying, there is no way to tell how big the cam is by hearing it lope in a video.
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
NewsBot
Feb 26, 2015 02:10 PM
NewsBot
Jan 29, 2015 07:10 PM
