Oil temp sender in the cylinder head?
Old Feb 17, 2008 | 02:46 PM
maybe2fast's Avatar
I want to get an oil temp gauge and don't want to tap the oil pan. The sender is a 1/8th sender, can I put it in one of the oil gally holes with the plug on the head? There will be oil pressure at the sender but should still give me a reading right?
thanks guys
Old Feb 17, 2008 | 03:08 PM
What? Oil pressure port in the head?
Old Feb 17, 2008 | 03:28 PM
mitchntx's Avatar
I have taken oil temp from a port just above the oil filter.
Old Feb 17, 2008 | 04:36 PM
I drilled and tapped the oil drain plug, and screwed the electronic oil temp sensor into the drain plug. Put a connector on it, so you can remove the drain plug when required.
Old Feb 17, 2008 | 05:51 PM
maybe2fast's Avatar
on the front or back of the head, depending which head you choose there is a small plug. Is that oil pressure behind that?
Old Feb 17, 2008 | 06:27 PM
Nope, that is a coolant passage. There has never been any oil pressure passage in any small block head.
Old Feb 17, 2008 | 08:25 PM
maybe2fast's Avatar
thank you.
will go to above the oil filter
HectorM52
Jul 30, 2017 11:46 AM
Chris Anderson
Jan 27, 2015 08:30 AM
Jessie4tin
Jan 7, 2015 08:53 AM
Elcojoe
Nov 17, 2014 10:27 PM
Jul 4, 2005 05:00 PM
