How do i know if my car is ODBII
Old Feb 17, 2008 | 08:11 PM
PWR-TRIP's Avatar
I have a 95 Z28, how do i tell if my car had ODBII?
I know my car was a special edition...Only 30,335 were made that year
Old Feb 17, 2008 | 08:20 PM
2000GTP's Avatar
Its an OBDI style PCM with an OBDII style diagnostics connector.
Old Feb 17, 2008 | 08:27 PM
PWR-TRIP's Avatar
That means?.....
Old Feb 17, 2008 | 08:30 PM
mdacton's Avatar
Originally Posted by PWR-TRIP
That means?.....
you have the obd2 connection under the dash but the diagnostic system is obd1....you need a scan tool capable of comunicating with obd1 through that conection
Old Feb 17, 2008 | 08:34 PM
2000GTP's Avatar
That means?.....
Courtesy of Shoebox:http://shbox.com/1/4th_gen_tech2.html#how_many_cats All LT1s of the 1995 model year were OBDI, not sure what you are trying to get at?
Old Feb 17, 2008 | 08:40 PM
PWR-TRIP's Avatar
The reason why i'm asking is...I'm thinking of doing an LS1 swap and someone told me that if your car has OBDII, the swap will be easier on ODBII then ODBI.
Old Feb 17, 2008 | 08:44 PM
2000GTP's Avatar
Personally, I don't see how it would make a difference. If you swap in an LS1, you are swapping the harness and PCM as well, along with all the sensors. Basically, anything from the LT1 platform is not going to interchange with the LSx platform so its not going to be a big deal. The main issue will be getting the wiring harness to work with your cluster gauges, but there is a company that can modify the harness to work with the instrument panel specific to your car.
Old Feb 17, 2008 | 08:53 PM
As 2000GTP said, it won't make any difference.
Jazsun
Dec 29, 2014 12:14 PM
1996LT1Z28
Middle Atlantic
Dec 4, 2014 09:37 PM
1996LT1Z28
Dec 4, 2014 09:20 PM
USAirman93
Nov 24, 2014 03:37 PM
