Airbag Delete, any links or picks to remove.
Old Oct 22, 2003 | 07:22 PM
LALT1's Avatar
looking for info on removing bags from a 94 Formula. Any info will be appreciated.
Old Oct 30, 2003 | 05:41 AM
slopokrodrigez's Avatar
I removed the air bag on the driver side when I replaced the steering wheel. I removed the firing mechanism from the old wheel and removed the coil from the steering column. Then so the light would not come on all the time and so the AIR bag test would pass, I taped the 2 parts together and stuck them under the dash.
I have not got a clue how to remove the passenger side. Be careful when you remove the coil in the steering column, it holds the 2 wires to the ignition switch for the VATs. Mine wore through and I had to bypass them.
Old Oct 30, 2003 | 05:57 AM
jasons93z's Avatar
May i ask why take it out unless it is going to be a strip car????? They saved me from serious injury in my 93 z28.
Old Oct 30, 2003 | 08:21 PM
No
Fastbird93
Apr 9, 2016 07:01 PM
HarleyZ28
Oct 5, 2015 06:23 AM
4586
Apr 29, 2015 01:43 PM
DrMilhouse
Aug 6, 2002 08:45 PM
sc93
Jul 26, 2002 02:02 PM
