Another Spark Plug Question
Old Nov 10, 2010 | 10:53 PM
FaustKnight's Avatar
My 95 Z28 has a 383 in it, with some unknown parts since it was built before I got my hands on it. So having some issues as I'm fixing gremlins left behind by the po.
What plugs should I run in a 383 with a mild cam? Special Gap? I put 8mm wires on it, and am getting ready to do the plugs, and all the other standard maint stuff. But I want to make sure I run the right plugs
Old Nov 11, 2010 | 06:20 AM
RamAir95TA's Avatar
Re: Another Spark Plug Question
The BEST thing to do would be to ask your tuner.
A very popular plug is the NGK TR55s (or TR6s for one heat range colder).
Old Nov 11, 2010 | 07:04 AM
95blkbird's Avatar
I know many people do not like the accel brand for whatever reason, but I run the accel silver shorty's. Due to header clearance issues mainly but I love them! I have put some decent miles on them so far and I have taken them out 2x to look them over. They have a perfect color, due to the tune mostly Im sure. I will probably never use a differant plug from here on out! Ive used ngk's, e3's, etc. but I love these!
Old Nov 11, 2010 | 08:39 AM
bw_hunter's Avatar
A point of clarification on the NGK plugs. TR55 is the stock replacement, with the stock gap in a copper plug. The TR55IV is the iridium tipped plug and is the direct stock replacement...there is no platinum plug. The TR6 is a copper plug, one heat range cooler, with a gap of 0.035 from the factory.
You can change the gap on the copper plugs but you should very careful doing so on the Irdium tipped versions as the electrodes are pretty tiny and look like they could break off readily. That sucks on a $7.00 spark plug....
The rule of thumb, based on a real world experience (not mine...collective experience) is to use 1 heat range cooler per extra hundred horsepower. Since I can't imagine someone building a 383 and not ending up with a hundred more horsepower than a stock engine you should have a 1 range colder plug. If you go with an NGK plug, try the TR6, part number 4177
There is no real concensus on the best plug. Lots of guys use NGK, plenty use Autolite, some (apparently) use Accel plugs and other swear by the stockers. Do the research and come up with your own conclusion.....
Old Nov 11, 2010 | 12:56 PM
I appreciate the help! Thanks guys
Old Nov 11, 2010 | 06:15 PM
multicar's Avatar
I'm running the platinum NGK plugs now after using the Autolite plats(AP106) for 35k miles. The NGKs are pre-gapped at .040 compared to the Autolites at .050.
ref: NGK TR5GP 3186
At 80k miles now and still stock, it's the smoothest its ever been. I left the gap at .040".
'96z28
mritter1965
Feb 9, 2015 07:01 PM
Iamherefornow
Jan 26, 2015 04:57 PM
Jazsun
Dec 29, 2014 12:14 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
