Oil pump pickup
Old Aug 12, 2007 | 12:19 AM
kline454's Avatar
Oil pump pickup
Well i have 1995 camaro lt1 383 im running the m155 oil pump, my oil pump pickup keeps falling off, about 2 weeks ago it fell off when i was going down the track, i seen the oil pressure drop off and saved the motor, it was just pressed in, lasted about 6mo. I was told it fell out because it wasnt welded, so i had it welded and all was good for about a week and now it fell off again!!! Does anyone make a bolt on for the stock pan??
Old Aug 12, 2007 | 06:02 AM
wrd1972's Avatar
The metal surface was not cleaned and prepped properly before welding most likely or the welder could not weld. I actually brazed mine together with a torch and coated brass rod.
Old Aug 12, 2007 | 10:48 AM
96capricemgr's Avatar
Once it comes out once the press fit is lost.
If you weld or braze it make sure you do not heat the relief spring and mess up it's pressure.
Old Aug 12, 2007 | 10:52 AM
wrd1972's Avatar
Uh huh, that is wise.
Old Aug 12, 2007 | 03:08 PM
kline454's Avatar
ok so is there a bolt on pickup or not?? how deep is the pan 7.5?
Old Aug 12, 2007 | 05:17 PM
bufmatmuslepants's Avatar
this is why i am going to have *** my project this weekend and not put my oil pickup back on, ive dealt with it for a year and a half i can deal for a while more.
HectorM52
Jul 30, 2017 11:46 AM
KYWes
Apr 15, 2015 05:48 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
carl.froehlich
Mar 13, 2015 12:38 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
