Oil pump and pan
Old Nov 17, 2010 | 09:28 AM
dugeman's Avatar
Oil pump and pan
I want to use a Moroso Billet pump ( # 22171 ) on my LT1 ( 383 ) . I had a Canton ( 242T pan on it , but the sump isn't deep enough for this pump, pan has to be 8.250 deep. Is anyone using this pump ,and what pan are you using . The car is a 94 Camaro with BMR tubular K member and motor plates .
Thank You .
Old Nov 17, 2010 | 10:08 AM
Z28SORR's Avatar
Re: Oil pump and pan
Have you tried calling or E-Mailing Moroso. They make a lot of pans, including custom apps.
Old Nov 18, 2010 | 08:21 AM
dugeman's Avatar
I spoke with one of their reps. on the phone , he said they don't have an off shelf pan , but could fab. one for around $500. That's not a bad price but I was looking for something not on that price range. My engine builder told me Milodon make a billet oil pump that will fit in the Canton pan. Thanks.
Old Nov 18, 2010 | 10:55 AM
RamAir95TA's Avatar
Why don't you use something that works? Canton 242T pan with Melling 10554 std. vol/high pressure pump and Canton 20-023 pickup? What says you HAVE to use a Moroso pump?
Change the pump/pickup, not the pan.
Old Nov 19, 2010 | 07:31 AM
dugeman's Avatar
We run a moroso billet pump on our 8.50 index car with excellent results , it was more the choice of the engine builder . We have found a billet pump from Milodon that will work with the Canton pan. Thanks
HectorM52
Jul 30, 2017 11:46 AM
KYWes
Apr 15, 2015 07:11 PM
KYWes
Apr 15, 2015 05:48 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
carl.froehlich
Mar 13, 2015 12:38 AM
