Air Pump Removal w/o tuning
Old Jul 15, 2010 | 09:08 AM
Alien's Avatar
I'm putting a '97 LT1 into a third gen racecar (not street legal, no cats etc).
I'd really like to not to have the CEL on after it's installed. Some guys have it constantly on, so they don't know if there is a 'new' problem. It's a racecar, I'm NOT allowed to tune out the codes, no opening of the computer at all.
I've read of a solution for the VSS (I'm still using the '92 T5, need a 4th gen tailshaft housing etc). O2 sims should work in lace of the rear O2 sensors. If I'm not mistaken, removing the Air Pump will activate the CEL. Is there anything I can do (resistors etc) to fool the ecm into thinking the Air Pump is there and working properly?
Old Jul 15, 2010 | 09:10 AM
purple 95 z28's Avatar
The air pump will not cause the check engine light to come on.
Old Jul 15, 2010 | 09:25 AM
Alien's Avatar
Interesting. I assumed it would based on the answer in this thread.
https://www.camaroz28.com/forums/sho...light=air+pump
No SES light or code on an OBD-I 93-95, as long as you have a good fuse in the AIR pump circuit.
I thought it was inferred in the way that was worded that OBDI wouldn't have a CEL but OBDII ('97) would. I know my '02 had a problem with the one way valve and it threw a code.
Old Jul 15, 2010 | 09:30 AM
My 95 (obd1) never threw a code. I just put LT's in my buddies 96 (obd2) a few weeks ago and it has yet to throw a code. Idont know why yours would.
Old Jul 15, 2010 | 09:31 AM
That is incorrect.
Even if you can fool the computer into thinking it is electrically there (which it will look for), an OBD-II PCM will be looking for evidence of the pump working by monitoring the O2 sensors. If it sees no expected change in a/f ratio when it is supposed to be on, it will throw a code for that. An OBD-I PCM does not do the a/f functional check and all you need is an intact relay and fuse in the circuit to keep the CEL off.
Old Jul 15, 2010 | 09:34 AM
Only putting LTs on would not cause a code. There has to be some details you left out.
Old Jul 15, 2010 | 09:39 AM
Explain why I took the air pump off my car and my buddies car when doing headers and no code has popped up?
Old Jul 15, 2010 | 10:14 AM
You said you put on LTs. You did not even say you removed the pump (details you left out).
It has already been explained. If the relay and fuse are left intact on an OBD-I car, there will be no code.
Your buddy's car should be throwing a code being OBD-II, unless you left out that he has done a swap to OBD-I. Maybe there are some particular conditions with his car to where it has not shown up yet. I bet it eventually will.
Old Jul 15, 2010 | 10:18 AM
bw_hunter's Avatar
He did ... You have an OBD1 computer which doesn't always set the CEL. The OBD2 system always does.....
Old Jul 15, 2010 | 10:22 AM
razor02097's Avatar
do the OBD 1 computers have a setting to turn off the AIR setting to prevent the SES light?
Old Jul 15, 2010 | 11:54 AM
The code reporting can be disabled.
Old Jul 15, 2010 | 02:38 PM
koolaid_kid's Avatar
I own a 97 LT1. The air pump was disconnected (and eventually removed) when the STS turbo was installed. The rest of the engine was totally stock. The air pump would occasionally throw a code until I disabled it in the tune. Actual experience, true story.
Old Nov 18, 2010 | 09:34 PM
bigdaddydj208's Avatar
Re: Air Pump Removal w/o tuning
I have a 97 lt1 and want to unhook the air pump, but dont want to kick a code, and so how would i disable it? or what would i have to do?
Old Nov 18, 2010 | 10:26 PM
Have the PCM tuned to eliminate the code/SES light.
Old Nov 19, 2010 | 10:05 AM
Z28SORR's Avatar
What kind of racing/class are you in that allows you to put an LT1 into a 3th Gen. but wouldn't let you "touch" the computor? And how would they know?
HectorM52
Jul 30, 2017 11:46 AM
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
cmdeshon
Dec 27, 2014 10:06 AM
CamaroZBoy
Sep 9, 2002 10:33 AM
CamaroZBoy
Sep 1, 2002 09:48 AM
