oil pump and oil pan question
Old Apr 11, 2005 | 07:28 PM
69vette's Avatar
I'm building a forged 383 with LE3 heads/cam and was wondering what oil pump and pan i should go with. Are stock replacements good enough or do i need a high flow pump?
Old Apr 11, 2005 | 09:11 PM
Robs97Z28's Avatar
Re: oil pump and oil pan question
most of what I've seen in here, guys or going with a stock oil pump with the white replacement spring.
Old Apr 11, 2005 | 09:32 PM
69vette's Avatar
where do you get the replacement spring?
Old Apr 12, 2005 | 02:18 PM
The stock pan and oil pump are fine, with a few cautions....
-a 383 crank may require some minor tapping of the pan with a hammer. Not sure about a 396, but it would probably be tighter.
-you need a windage tray.
-the oil pump should be new, and "blueprinted".... clearances per specs, all burrs removed, etc.
-pickup should be tack welded after verifying you have the correct clearance to the pan.
Old Apr 12, 2005 | 06:35 PM
69vette's Avatar
isn't ther already a windage tray with the factoy set uo?
Old Apr 12, 2005 | 06:43 PM
DrewHMS97SS's Avatar
the stock tray mounts to 3 studs off of the main bearing caps. i had major issues with my pan/383 setup and ended up getting a canton pan. The stock oil pump is fine, but you do want to buy a new one. I have a brand new meling pump that i didnt end up using (long story) that i will sell for 25$ if you are interested.
Old Apr 12, 2005 | 07:28 PM
69vette's Avatar
why did you opt for a factory replacement over the meling?
HectorM52
Jul 30, 2017 11:46 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Queens94z28
Dec 20, 2014 09:11 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
