Oil pump needle fluctuates
Old Feb 22, 2003 | 10:23 AM
Se7ix's Avatar
The needle on my oil pressure gauge in my car fluctuates abnormally. Sitting at a light with the car warm, I've noticed it will bounce up slightly, settle back down, maybe bounce up a little more or less, drop down again, etc.
When cold, it runs at max pressure as it should. I have only noticed this fluctuation whenever the engine is warm.
Anyone have any ideas? Is this a hint of a bad electrical (something) about to break?
Thanks,
-John
Old Feb 22, 2003 | 10:28 AM
94SLUG's Avatar
100 to 1 says oil pressure sending unit easy install and around 45 bucks. Buy delco and there is a 1 percent chance its your oil pump.
Old Feb 22, 2003 | 05:50 PM
cals400ex's Avatar
maybe i don't understand what your saying but when your car is warm the oil pressure will drop. this is because the oil thins out as it gets warm. at idle it will be the lowest. when your driving your oil pressure will go back up. if it is bouncing around, i would try replacing the oil pressure sending unit.
HectorM52
Jul 30, 2017 11:46 AM
KYWes
Apr 15, 2015 07:11 PM
KYWes
Apr 15, 2015 05:48 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
NEWBIE T/A
Jun 14, 2002 12:27 AM
