Oil Pump Mounting
Old Jun 2, 2007 | 10:25 AM
Chevycobb's Avatar
Oil Pump Mounting
Im using a standard volume pump, but I lost the stock oil pump bolt somehow. Is there a certain part number for the bolt or can a grade 8 bolt of same size work? If so, does anyone know the size.
I found a stud that ARP makes for SBC pumps, but wasn't sure if that would work or not.
I found this one, and then there is another one like it but is 3.125 inches long.
Old Jun 2, 2007 | 02:42 PM
sssalah's Avatar
I'm using ARP studs on both my LT1 cars. The longer one is for high volume oil pumps.
Old Jun 2, 2007 | 03:12 PM
Chevycobb's Avatar
Ok, I went ahead to summit and purchased the stud(and a few other things I needed) The stud seems too short though, the top of the nut sits higher than the top of the stud, and thats without the washer.
Old Jun 3, 2007 | 07:32 AM
Chevycobb's Avatar
any ideas about that stud maybe being too short? I'll measure again and make sure. the pump isn't a high volume pump, but it is a high pressure pump.
Old Jun 4, 2007 | 12:46 PM
Heatmaker's Avatar
Advanced Member
Dealer
Old Jun 4, 2007 | 01:31 PM
Chevycobb's Avatar
Originally Posted by Heatmaker
Dealer
would love too because it would so much easier, but by the time I get off of work and get there the parts department is closed.
I measured the depth for the stud with the pump on and the one for a HV pump would work perfect so ill pick one up. wish I measured the first time instead of going off of part descriptions. live and learn...
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
carl.froehlich
Mar 13, 2015 12:38 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
Jul 4, 2005 05:00 PM
