oil pump disassembly
Old Sep 16, 2008 | 01:32 PM
sn8ke eatr's Avatar
i ordered a new melling hd pump and it just came in, however, its just the body, it dosent come with the pickup or the rod. my question is how to remove these pieces from the old pump without damaging them. the pickup is just pressed in right? so is it safe to put the old pump in a vice and wiggle it out? and is there a trick to getting the shaft off? i cant do it lol
Old Sep 16, 2008 | 02:48 PM
camaro1fastz28's Avatar
spray the pick up with keyboard dust spray but use it upside down and the pick up come out easy and as far as the rod get a new plastic peice from ur local machine shop they are lik $0.50
Old Sep 16, 2008 | 03:43 PM
Don't use the old pickup and don't use a plastic sleeve on the driveshaft (use a driveshaft with a metal sleeve like the Melling IS-55E -Autozone has them). Pumps with a pressed in pickup usually don't come with the pickup and most don't come with a drive shaft.
Did you mean you bought an HV pump? I hope you have read the many threads recommending you not use that on a stock pan. Also be prepared for possible extra wear on the oil pump drive (not the driveshaft) if using an HV pump.
HectorM52
Jul 30, 2017 11:46 AM
KYWes
Apr 15, 2015 07:11 PM
KYWes
Apr 15, 2015 05:48 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
carl.froehlich
Mar 13, 2015 12:38 AM
