Spark plug wires
Old Sep 16, 2008 | 03:58 PM
stvski80085's Avatar
Spark plug wires
Ok guy's, I have searched and found lot's of info but want an update. I want to run my wires otvc. Do they sell any good sets that are premade or do you have to get the ones you cut yourself? I saw elite used too but bad reviews and it doesn't look like they are still in business. I am not worried about getting the ones you cut and put ends on but if they make some already cut then I would like to take a look at them. I keep having problems with the passenger side burning wires. I have some sleeves I bought but I was too late. Should have done it when I first put them on. Also what do you have to do to mount the looms to the valve cover? Any suggestions or ideas would be helpful? I currently am using MSD 8.5 wires but a couple are toast.
Old Sep 16, 2008 | 05:03 PM
2000GTP's Avatar
Elite is no longer in business, you will have to buy the universal wire set and make your own. Made 4 U makes a nice wire loom set and you can get those from Thunder Racing or Summit. The loom set comes with long bolts that simply take the place of your valve cover bolts. You can try doing the stock wire setup, you just have to be sure to secure the wires that are touching the primaries with some cable ties.
Darth_tsunami
V6 Tech
Sep 18, 2015 01:57 AM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
Jazsun
Dec 29, 2014 12:14 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
