Oil problem, gauge or engine, questions...
Old Jun 21, 2004 | 10:57 AM
350 HRSS's Avatar
Hey all,
We have a 94 Z added to the group of F-bodies, and are having some problems. And I know this is where to come first
Anyway, it has about 102k miles on it. We are having oil leaking from somewhere in the front, and somewhere in the rear. I am guessing timing chain cover and rear main seal???
The other bad problem is that Sat. night, we were pulling into our road, and his oil pressure went to 0. He pulled over, and started to cut off the car, but then, the guage went RIGHT BACK to normal. Is this an elec. problem??? Or is something really wrong w/ the sending unit, or oil pump???
BTW, it will leak about half an ounce or so overnight. We check it every time before it is driven. Anyway, just wanted to get some diagnosis from some of you on here first.
We appreciate it
TAI!
Old Jun 21, 2004 | 11:48 AM
Sounds more like an oil level or pickup problem. The gauge wire would have to be grounding out for it to cause the gauge to read 0.
Old Jun 21, 2004 | 11:52 AM
Spinner's Avatar
Sounds like a pickup problem. Ask me how i know this
Pull the oil pan and get your pickup fixed.
Old Jun 21, 2004 | 12:06 PM
350 HRSS's Avatar
What all is involved in fixing the pickup???
Thanks...
97z28k&N
Jan 9, 2015 04:58 AM
NorthPoleDev
Dec 31, 2014 03:20 PM
cmdeshon
Dec 27, 2014 10:06 AM
siguy
Nov 27, 2014 10:07 AM
blac94Z
Nov 24, 2014 07:12 PM
