I want an Ignition system
Old Jun 18, 2004 | 11:49 PM
19camaro71's Avatar
I am planning to put an ignition system in on my 93 formula. I have doen that search and heard good things about accel. I have heard good and bad about MSD, and I haven't head much about crane.
I know a lot of people wouldn't recommend an ignition for a basically stock car, but I believe that it is a good place to start and that every mod after that would yield better results.
I have heard that Aftermarket ignitions burn up optis. Is this true? My car has 78000 miles, would it fry mine?
I am leaning towards an MSD digital 6 plus. I want the box and the standard blaster coil made for GM dual connector. Is there anything else I need besides the Digital 6 plus box, the blaster dual connector coil, and the wiring harness?
Anything else I would need to know about this?
Old Jun 19, 2004 | 12:00 AM
Zepp's Avatar
Get the Delteq system to eliminate the Opti and convert over to coil packs. It is a really nice setup. I am glad I did mine.
Old Jun 19, 2004 | 12:34 AM
ibanez6rg's Avatar
The Delteq unit doesn't completely eliminate the Opti, atleast not yet.
Old Jun 19, 2004 | 10:19 PM
19camaro71's Avatar
so... this delteq system is good?
I still want the conventional system... with the optiand ignition.
can anyone answer my questions?
Old Jun 19, 2004 | 10:40 PM
stroked383ta's Avatar
i would get a crane cams hi-6s and a ps-91 coil. both very good products. btw, im selling mine . if you're interested, pm me. im selling them for a good price.
Old Jun 19, 2004 | 10:51 PM
n2ceptor's Avatar
You wont have any significant HP gains, just better idle and maybe acouple of miles per gallon.....
I have an Accel 300+ on my 93Z and didnt notice a difference.. Its disconnected now, saving up for the Delteq...
Old Jun 19, 2004 | 11:10 PM
Fatdog's Avatar
Cool
Stay stock.(except plugs)
Old Jun 19, 2004 | 11:35 PM
ninetythreez's Avatar
I like my MSD stuff. You have a M6 I see. Gears would be a better mod for your $$ probably. Gears would make more of a noticable gain for the $$ in your car I bet.
Old Jun 20, 2004 | 03:20 AM
5.0THIS's Avatar
the ignition box is really not needed in this case. I think if you want most of the benefits, just get a better coil, which should get you some help with idle and gas mileage as was mentioned above (althought these gains will be negligeble if at all)
Old Jun 21, 2004 | 12:15 PM
19camaro71's Avatar
I've got the factory 2.73 gears right now and recently replaced ac-delco platinum tip plugs. (with accel 8mm spiral core wires) what plugs should I get then?
From what I read, a box is useless? I am not looking for major gains, just dependability and a better idle and the like. If the box won't do this then I guess I don't want it. I should just get the MSD blaster coil or what?
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
Mar 13, 2016 03:39 PM
ad356
Apr 11, 2015 11:12 PM
Ari G
Dec 11, 2014 03:21 PM
