Oil Pressure at WOT????
Old Dec 26, 2003 | 08:06 PM
S.J.S.'s Avatar
Hey guys. I was just wondering what kind of pressure are you guys getting at WOT. When I have the stock motor it used to go up to like 60. Now it barely moves. If I'm like rolling at 50mph and I nail it. The pressure goes from like 40 to 45/50. Is that normal because I have a high volume pump???
Old Dec 26, 2003 | 08:31 PM
Hotwire's Avatar
try changing your oil man, sounds like it may be running thin.
I'm also running a melling hv on my lt4 conversion, i'm usually in the 55-60 psi @ wot. usually at cold/idle the thing is pegging the meter at 80 psi. right now i'm running mobil 1 10w-30, deleted factory oil cooler, and a napa gold oil filter.
Old Dec 26, 2003 | 08:34 PM
S.J.S.'s Avatar
Well Im running 10-30 right now and my motor is only 1500 miles old. Wonder if the Canton Pan has anything to do with it. When just running regular its normal. 40psi when cold then drop to about 25 when hot. On the freeway its like 40ish.
Old Dec 26, 2003 | 08:37 PM
Hotwire's Avatar
did you clearance your pickup for the canton oil pan? weld in the pickup tube to the pump to make sure it won't fall out? seat it fully in the pump?
what oil filter you running?
Old Dec 26, 2003 | 10:33 PM
S.J.S.'s Avatar
I'm using the pick-up that came with the pan. Got it from Nu-Tek, as a package. Well I think I got it figured out. When I put in the pump Nick advised me to put in the optional spring. Its not the high pressure spring so it probably bleeds off after 50psi or something. Cause all my other pressure is normal.
Old Dec 26, 2003 | 11:00 PM
97 RedSS's Avatar
Pick-up was welded on correct? Also did you check the distance the pick-up was from the pan? That is very critical..I have the same set-up and I see about 65-70 psi at cold start and when it warms it sits right above 40psi at idle. When cruising it sets at 55-60psi..
Cody
Old Dec 26, 2003 | 11:06 PM
97 RedSS's Avatar
Im using the spring that came with the pump and not the lower pressure spring btw..
Old Dec 28, 2003 | 10:19 AM
S.J.S.'s Avatar
anyone else???
Old Dec 28, 2003 | 01:08 PM
Hotwire's Avatar
I'm also using the high pressure spring. I didn't know you were using the low press spring, you should be alright, that states that it is for stock pressure readings.
how long ago did you change the oil? i usually notice the oil breaking down and not giving a high reading when I'm getting close to 3k miles when using conventional oils.
HectorM52
Jul 30, 2017 11:46 AM
Nickster 7
May 1, 2015 09:04 PM
surreybrad
Apr 22, 2015 06:40 AM
KYWes
Apr 15, 2015 05:48 AM
ad356
Apr 11, 2015 08:49 AM
