Oil pressure went to zero!
Old Dec 5, 2003 | 06:31 PM
97Z-pimp's Avatar
Unhappy Oil pressure went to zero!
Well this morning on the way to school my check guages light came on and my oil pressure was sitting on dead zero. I stopped immediatly and checked my oil and it was full. I had it towed home cause the oil would not leave zero. I drained the oil and it was perfectly clean. Maybe it is the oil pump or the sending unit or something else. I also did LT headers like a week before if you think it might have something to do with it. Any help or suggestions would be appreciated.
Old Dec 5, 2003 | 07:37 PM
WrecklessZ's Avatar
Worn oil pump.
Loose or disconnected pickup.
Open pressure release valve.
Clogged pickup screen
or like U said the sending unit
Old Dec 5, 2003 | 07:42 PM
drewstealth's Avatar
Well if it was just at zero and did not move at all then it is probably the sending unit like you say. Since the oil is nice and clean and if you didn't hear any weird noises, thats probably what it was.
Old Dec 5, 2003 | 08:34 PM
bigde4u's Avatar
I would try that first. Always go by the K.I.S.S rule!
Old Dec 5, 2003 | 08:43 PM
nitropatch's Avatar
if its not the oil sending unit, i woud jast your motor up and take the oil pan off and see if you spun barings those go out if your oil guage hits zero, i know this too well
Old Dec 5, 2003 | 10:30 PM
93formula's Avatar
same happened to me, was the sending unit.
Old Dec 6, 2003 | 01:26 PM
97Z-pimp's Avatar
Well i found the culprit and the oil pressure sending line was crimped under the valve cover. I cut out that part of the line and replaced it with new wire. Now the oil pressure is pegged out and i dont know whhat to do now. Any suggestions????
Old Dec 6, 2003 | 01:37 PM
Fastbird93's Avatar
If it's pegged out then you may have grounded it out somehow when you replaced the wire. I don't remember exactly, but wasn't it a two wire setup on the oil pressure sending unit???
Old Dec 6, 2003 | 01:57 PM
97Z-pimp's Avatar
I got it fixed! the wire going into the clip of the sensor was not in there to good but now it is and i have a good reading of oil pressure
Old Dec 6, 2003 | 02:15 PM
bigde4u's Avatar
Old Jul 18, 2004 | 08:07 PM
Camaro94Lover's Avatar
Re: Oil pressure went to zero!
Nothing like a bad sending unit or wire to give a person a heart attack. At least that is all it was.
Old Jul 18, 2004 | 09:56 PM
Just to clarify for those that may read this thread later, the crimp you found on your wire was grounding out the gauge. That caused your zero reading. When you "fixed" the wire, you left it open to the sensor. This caused the gauge to be "pegged". When you finally got it connected, all was well again.
There is only one wire on the f-body oil pressure sending unit and it goes to gauge.
[edit] Just realized this was a thread resurrected from the dead.
HectorM52
Jul 30, 2017 11:46 AM
Nickster 7
May 1, 2015 09:04 PM
surreybrad
Apr 22, 2015 06:40 AM
KYWes
Apr 15, 2015 05:48 AM
ad356
Apr 11, 2015 08:49 AM
