The Pacesetter mids header install has begun any tips???
Old Jul 16, 2004 | 05:25 PM
TexasTechTA's Avatar
well justs atrted this afternoon and can only work on the car in chunks of spare time. i already have the alt off, belt, a few y pipe bolts, o2's dissconnected. drivers side ari fitting.
Any tips for removing stock headers?
The y pipe bolts are a little tight would wd40 soaking help?
also how do i remove the air fitting on the pass side?
Old Jul 16, 2004 | 06:22 PM
never mind got the y pipe off, but I disconnected the o2 sensor on the drivers side but the female end connector is attached to a plactic piece how do I unattach it?
Old Jul 16, 2004 | 06:28 PM
turbo_Z's Avatar
The female end is part of the harness and attaches behind the drivers side head if i remember right.. if that sounds correct then I believe the connector simply slides off the clip.
Old Jul 16, 2004 | 08:05 PM
never mind I got it I was not haveing trouble unplugging it it was just caught on soemthing. anyway I have the y pipe, drivers headers off now.
now for the passenger side. do I need to remove the dipstick tube? if so how do i do that
Old Jul 16, 2004 | 08:32 PM
I feel great about myslef, although I know the hard part the pass side is to come.
anytips for getting the pass side botls out?
also how do i get the pass side air fitting off?
Old Jul 17, 2004 | 12:13 AM
camarokid24's Avatar
PB BLASTER get you self a can and spray the manifold bolts as best you can and let them soak in for a while. For me getting all the old restrictive parts off was the easy part. Just wait till you realize that you need to jack you car another foot up to get your headers in LOL .....j/k it's not too bad. Oh also If you are doind OVC wires I would also recommend using WD40 in the boots for the opti and on the connectors ends. I tried and tried to get those dang things on there with the silicone greese to no avail. Spray it up and slip it on. One less head ache Good luck and have fun. Oh yeah about the dipstick tube yes you have to remove it . Simply remove the mounting bolt and wiggle and pull up and over. be careful when pulling on the rubber part at the top I schreded mine.
Old Jul 17, 2004 | 12:34 AM
so is the hard part removing the stock manifolds or putting the ehaders on. My plugs and wores are farily new so i am not changing them so that is one less thang
Old Jul 17, 2004 | 12:37 AM
Well I put long tubes on my car and they were the hard part. Getting the old stuff off was a peice of cake.
Old Jul 17, 2004 | 01:12 AM
krispy's Avatar
from what ive heard you wanna unbolt the dipstick then loosen the passenger manifold to make it easier to get out, apparently some bending of the dipstick tube is required
Old Jul 17, 2004 | 01:39 AM
You want to take the dipstick tube out AFTER you get the manifold out. I didn't need to bend it at all. Helps to have two sets of hands though someone up top pulling and someone down low pushing and twisting.
Old Jul 17, 2004 | 01:52 AM
Kris93/95Z28's Avatar
For mids getting the old stuff out is the PITA for LTs getting the new stuff in is the PITA....
My suggestion is PB Blaster every damn bolt hours before you touch it and once again before you go to remove it.
Those headers the driver side will go in from the top (Cake), passenger will go infrom the bottom, not as easy, but if tweaked just right will fit.
WATCH the fittings on the headers I had a set of Pace Setter Mids on my 93 Z28, and they were TOTTALLY the wrong size... Needless to say they stripped out the stock connectors and I ending up doing !AIR/!EGR because of those headers.
Old Jul 17, 2004 | 08:43 AM
the pacesetter mids were redesigned a year ago to fix any problems and have friends who love them.
The y were also only 261 bux shipped with y pipe.
also yes they look fairly easy to install but not that easy comom its still an lt1. well i am making a road trip and will continue the header journey tonight.
Thanks guys,
BTW how should I go about installing the new gaskets?
should I glue them to the headers and put in? or try to thread a bolt thru on each end to keep them in place?
Old Jul 17, 2004 | 09:14 AM
I didn't use any gasket stuff with mine
Old Jul 17, 2004 | 10:10 AM
Scream And Fly's Avatar
Which gaskets are you using?
Old Jul 17, 2004 | 10:27 AM
I used Felpro 1406 gaskets
