oil pressure sensor
Old Jun 16, 2009 | 03:39 PM
  #16
JAKEJR's Avatar
Originally Posted by Injuneer
As we can see from the notes Shoebox added to his photo, the 94 can have its oil pressure sensor in two different locations, depending on whether it was produced "early" or "late" in the model year.
It never ceases to amaze me how GM continues to change the locations of their sensors and senders. This is yet another example.
On my 96 Vette, the hole above the oil filter is for the OIL TEMPERATURE SENSOR and the OIL PRESSURE SENDER is behind the intake in a tee with a FUEL PRESSURE SWITCH which operates on oil pressure.
Go figure.
Jake
West Point ROCKS!
Old Jun 16, 2009 | 05:57 PM
  #17
NJ-LE's Avatar
94Z28KC4-GU5-PO5
"so above the oil filter was just the old location on previous camaros & then they put it behind the intake on later models for no reason at all?"
Probably economics ... ~ 2 feet less wire used, times however many Camaros built after the change. (I wonder how many miles of wire were saved @ X$/mile?)
Old Jan 29, 2011 | 12:38 PM
  #18
Rich2279's Avatar
Re: oil pressure sensor
Is the connector the same for both sensors ('93-early '94 and late '94 -'97)?
Old Jan 29, 2011 | 01:26 PM
  #19
Shoebox has a list of the part numbers for the various connector pigtails, and there is only on number shown for the oil pressure sensor:
http://shbox.com/1/Parts.htm
Old Jan 29, 2011 | 07:17 PM
  #20
Rich2279's Avatar
Cool, thank you.
HectorM52
Jul 30, 2017 11:46 AM
KYWes
Apr 15, 2015 05:48 AM
phoenix95
Jan 8, 2015 02:44 PM
phoenix95
Jan 8, 2015 09:14 AM
Jul 4, 2005 05:00 PM
