oil pressure question?
Old Apr 18, 2006 | 02:03 PM
crAzy95z28's Avatar
well after i fixed everything on my car about the oil pressure. While cruising around town around 40-55 mph the oil pressure sits at around 35 psi in OD, but if i drop it in drive it goes up to about 45.
Idle is 20 and wot is 70. Now im thinking the oil filter (ac delco) could be a cause of a little bit low oil pressure at cruising along with 10-40w penzoil.
Now my next change will be mobile 1 synthetic, prob 5-30 or 10-30 with a witz 1qrt oil filter.
Now u think this would make the pressure come up some or actually make it drop even lower?
Old Apr 22, 2006 | 08:29 PM
crAzy95z28's Avatar
Re: oil pressure question?
anyone?
Old Apr 22, 2006 | 08:33 PM
OBE1 95Z28's Avatar
You oil pressure values sound right to me; what values are you expecting?
Old Apr 22, 2006 | 08:39 PM
crAzy95z28's Avatar
40-50 at cruising!
Old Apr 23, 2006 | 12:39 PM
OBE1 95Z28's Avatar
A "rule of thumb" posted here often is 10# of oil pressure for every 1,000 rpm; so most people cruise at about 2,000 rpm = 20# of oil pressure.
Old Apr 23, 2006 | 12:45 PM
The oil pump is effectively a "positive displacement" pump. The volume of oil it pumps is directly proportional to the RPM of the engine. It is completely normal that the oil pressure will drop when you shift it into overdrive. There is nothing wrong with what you are seeing.
Old Apr 23, 2006 | 01:44 PM
crAzy95z28's Avatar
k good.
HectorM52
Jul 30, 2017 11:46 AM
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
transam_388
Mar 15, 2015 11:53 AM
Jessie4tin
Jan 7, 2015 08:53 AM
Jul 4, 2005 05:00 PM
