Oil pressure not what is used to be???
Old Nov 3, 2005 | 12:47 AM
ss#1230's Avatar
hey guys, my oil pressure is right at 20 at idle. i thought it used to be closer to 40 while idling.
i might be trippin though, i dont drive it very often. what pressure are you guys seeing???
thanks.
jeremy
Old Nov 3, 2005 | 01:10 AM
FastZinTennessee's Avatar
Re: Oil pressure not what is used to be???
That seems to be about normal. Mine was actually a little lower than that, and I never had any problems with the oiling system- the bearings actually looked really good when inspected.
Old Nov 3, 2005 | 01:11 AM
2000GTP's Avatar
Mine is about 18-20psi at idle.
Old Nov 3, 2005 | 01:35 AM
Ray86IROC's Avatar
Mines around 15-18 indicated on the dash gauge at really good and hot oil temp at idle (w/ an auto that's just slightly above 600 rpm I guess). Cruising at a little under 2000rpm good and hot it's about 25-30 psi or so, and at WOT it's between 35-40 psi. 139k miles...
Can't say I'm too comfortable w/ these levels myself but it's above minimum specs from what I understand... I'm halfway scared to get a mechanical gauge and double check the actual numbers for fear of getting lower readings, lol.
HectorM52
Jul 30, 2017 11:46 AM
Nickster 7
May 1, 2015 09:04 PM
surreybrad
Apr 22, 2015 06:40 AM
KYWes
Apr 15, 2015 05:48 AM
ad356
Apr 11, 2015 08:49 AM
