"Oil Pressure Low at Idle"
Old Jan 14, 2005 | 12:05 AM
  #16
turbo_Z's Avatar
Re: "Oil Pressure Low at Idle"
Pretty sure the pickup tube isnt the problem since the pressure drops once the oil is warm. Try using a mechanical gauge to see what the pressure really is before panicing. If the pressure is still low though then you will probably be looking at a rebuild.
Old Jan 14, 2005 | 06:30 AM
  #17
SStrokerAce's Avatar
Just a reference for you guys on this thread.....
http://web.camaross.com/forums/showthread.php?t=331346
Bret
Old Jan 20, 2005 | 01:16 AM
  #18
ptown's Avatar
Exclamation Re: "Oil Pressure Low at Idle"
ok it wasnt the oil pump or the pickup but I replaced the oil pump anyways while I had it appart. Since its not the oil pump do you think if I replaced the cam bearings the problem would be gone. Ive wanted to put a lt4 hotcam in anyways.
Old Jan 20, 2005 | 02:22 AM
  #19
MaxLean's Avatar
Cam bearings are RARELY a problem. And you can't really change them in the car.
Old Jan 20, 2005 | 07:43 PM
  #20
1racerdude's Avatar
Cam brgs are a common problem with a cam change.
GM didn't put a quality cam brg in the LT-1 and they won't take the extra spring pressure. Especially the front one that is over loaded just driving the water pump.
If there was no gold or silver metal in the oil pan they may not be hurt.Try changing to a straight 30 or 40W and see if it helps. Or go with a 20/50W. If the pressure comes up you may have a brg problem,that is wear and may not be a problem with the thicker oil,but..... It also depends how this problem developed,all of a sudden or gradually.
You might take the oil cooler off and throw it away,they are a restriction.
Old Mar 18, 2005 | 12:57 PM
  #21
EKO's Avatar
EKO
My V6 has been idling at bout 5-6 psi when it gets hot for about 4 years. I've got 124K on it and no serious problems with it. Just as long as it goes back up when you give it the gas...
Old Apr 10, 2005 | 03:09 PM
  #22
CamaroSS30thAnn's Avatar
my oli pressure dropped to 0 when i went hard around a corner , and the check guages light came on , i revved it and everything went back to normal
anybody know what that could be ??
Old Apr 10, 2005 | 06:55 PM
  #23
Spinner's Avatar
Oil pickup or low oil level. Put that shift kit in recently?
Old Apr 11, 2005 | 12:29 AM
  #24
checked the oil it was full , shift kit is not in yet
u really think the pickup could have fell off , y would it go back up ot normal operating psi?
HectorM52
Jul 30, 2017 11:46 AM
KYWes
Apr 15, 2015 05:48 AM
ad356
Apr 11, 2015 08:49 AM
transam_388
Mar 15, 2015 11:53 AM
Jessie4tin
Jan 7, 2015 08:53 AM
