Oil pressure low!!!!!
Old Apr 7, 2008 | 08:40 PM
BMD18's Avatar
Hi i really appreceate your guys help with my other threads!!!!! I have a lil oil pressure problem its fine when i start it up and when the motors cold but when it warms up it lowers and then when it idles it almost hits 0 its like right above it i would really hate to be depriveing my motor of well deserved oil!!! Maybe its because my oil pump it just old or maybe my oils thin i run 10W 40!! i was talking to a guy at Auto Zone he said to Run some OIL STABILIZER i just need some opoions!!! thank you agian
BOW TO THE Z28
I have a 95 LT1 5.7L Stock with a 700R4 Tranny!
Old Apr 7, 2008 | 10:36 PM
96' Formula WS6's Avatar
How many miles are on your car. This will affect the oil pressure as bearings wear out over time.
Old Apr 8, 2008 | 06:29 AM
maverickmk's Avatar
according to the LT1 - LT4 rebuild book in the Appendix on Page 179 it says the factory specs on oil pressure should be at 6 psi at 1,000 rpm; 18 psi @ 2,000 & 24 psi @ 4,000 rpm - you may want to get a mechanical gauge and see if you are getting some oil pressure at idle, I would think you are or you'd be hearing some clanking noises by now.
Old Apr 8, 2008 | 08:11 AM
Pontiac_97's Avatar
i would change the sending unit thats located on the back of the intake manifold. i know they do go bad a cause crappy pressure readings. you need a special kind of socket to take it off. or hook it up with a mechanical gauge like the other guy said
Old Apr 8, 2008 | 08:27 AM
pizzi-man's Avatar
Try running some good old fashion 40W racing oil for about 3 months.
Old Apr 8, 2008 | 08:55 AM
The_Bishop's Avatar
Why would he do that? If the problem is the gauge, the overly thick oil will not help. Diagnosis first, fixes afterwards. Plug in a mechanical gauge, see what your readings are.
Old Apr 8, 2008 | 11:28 AM
87bandit's Avatar
maybe your oil pickup fell off
hit the bottom of the pan with your palm when the oil is drained and listen for a sound
or the oil pressure sensor is shot, happened to me
Old Apr 8, 2008 | 07:36 PM
brianswimmer23's Avatar
look and see if their is oil on the back of the engine and egr valve showing signs of a leak!might just be a bad oil pressure sending unit!
HectorM52
Jul 30, 2017 11:46 AM
KYWes
Apr 15, 2015 05:48 AM
ad356
Apr 11, 2015 08:49 AM
transam_388
Mar 15, 2015 11:53 AM
Jessie4tin
Jan 7, 2015 08:53 AM
