Oil pressure help.... ASAP PLEASE!
Old Nov 20, 2004 | 06:47 PM
ollie-99's Avatar
OK i start my car and the oil pressure guage is pinned to the max; then from there after about 5 min of being @ max it will go down to about half on the guage then goto under 20psi and when i stop down to nothing; if i rev the motor the pressure does go up;
recentrly ive had my oil sending unit replaced b/c it was leaking and ever since it was replaced @ start up the guage would get pinned to max then go to normal and be ok; and just the last 2 days its been acting up
Any suggestions? i was told it may be the guage cluster or sending unit?
Old Nov 20, 2004 | 07:17 PM
Scream And Fly's Avatar
Re: Oil pressure help.... ASAP PLEASE!
Does it go to zero while braking? If so, check the oil pickup tube.
Old Nov 20, 2004 | 07:34 PM
1racerdude's Avatar
If this has only happened since you replaced the sender,I would say wrong sender.Check it with a manual guage to verify.
HectorM52
Jul 30, 2017 11:46 AM
surreybrad
Apr 22, 2015 06:40 AM
KYWes
Apr 15, 2015 05:48 AM
ad356
Apr 11, 2015 08:49 AM
transam_388
Mar 15, 2015 11:53 AM
