Oil Pressure Guage (Bad??)
Old Oct 17, 2007 | 11:13 AM
PMC_93LT1's Avatar
Just wondering if there is an easy way to tell if your oil pressure guage is bad or whether your oil pump is truly going insane. I have a 93 LT1 and when the car is started the guage immediately pegs well past 80. I am wondering if there is an easy way to tell if it is the guage or the oil pump. The dealer I got it from said it was the guage but you never know.
Also, I know this part may be off topic here but anyone have any things to check on for nonworking automatic door locks. Occasionally when the drivers side button is pressed it sounds like something is making noise under the dash like a clicking sound. Maybe like a connection is being made but not continuing beyond that point.
Old Oct 17, 2007 | 11:17 AM
If the wire comes off the sensor, or the sensor fails "open", you will get full deflection (80psi) on the dash gauge.
Old Oct 17, 2007 | 11:24 AM
TrybalRage's Avatar
Oil pressure sensor failure or as Injuneer said, the connector came off.
Good luck, they are a bear to change, and you are doing it blind.
Old Oct 17, 2007 | 11:32 AM
PMC_93LT1's Avatar
Do I need to look at the guage on the back of the instrument cluster? Or would I need to look somewhere else. I am okay mechanically and my father knows cars better than I do so if I know roughly where to look I am sure I can take it from there or my father would know.
Old Oct 17, 2007 | 11:42 AM
dangalla's Avatar
the sensor is what your after, its behind the intake manifold slightly off to the drivers side
Old Oct 17, 2007 | 12:00 PM
He has a 93. His sensor is located on the drivers side of the block above the oil filter.
Old Oct 17, 2007 | 12:10 PM
PMC_93LT1's Avatar
Thanks, I will go check that out and see what I find.
HectorM52
Jul 30, 2017 11:46 AM
transam_388
Mar 15, 2015 11:53 AM
Jessie4tin
Jan 7, 2015 08:53 AM
Jul 4, 2005 05:00 PM
GigaMp3z
Feb 20, 2003 02:57 PM
